1995 Camaro bogging down
Old 07-15-2013, 01:01 PM
elite.inc's Avatar
Hello,
I have a 1995 Camaro 3.4L. I recently went through and replaced the water pump, the timing cover gasket, and the temperature sensor. Everything went smooth. After the work is done it started right up no problem and idles good. When driving it feels as if the acceleration is not there at all. If I am lucky enough to get up enough speed to get to fourth gear no matter how much gas is given it boggs down and loses speed all by itself. I went through and double checked everything to make sure everything was back where it needed to be. Any suggestions on what I could possibly check from here would be greatly appreciated. Thank you
elite.inc is offline
Jlo
02-03-2015 09:41 PM
01-05-2015 07:14 PM
SLIMJIM
01-07-2003 11:06 AM
slothgrant
08-22-2002 03:01 PM
Chrisdude
07-24-2002 02:25 PM
Quick Reply: 1995 Camaro bogging down
