02 Camaro Battery Light
Does the 02 Camaro have a battery light that comes on when the alterntor takesa dump? I looked at my alt today and noticed it only had 1 wire going into the regulator plug. I thought there should at least be 2. 1 that excites regulator and 1 for the bat light on the dash. According to a wiring diagram, it should have 2. I don't even see another wire hanging where it could have been cut. I traced the harness all the way back to the rear of the intake and no loose wires. What do I do? I do have a volt gauge, but I thought it should have a light as well. Thanks in advance.
The LT1 4th gens have only one wire (exciter) other than the battery cable and a "check gages" light that may come on if the voltage gets too low (aside from the volt gauge). The ABS light will usually also come on if voltage is low.
I just found a wiring diagram for a 2000 Camaro. It only uses one small wire to the alternator as well.
The replacement alt ppigtail I found has 2 wires. I also read that it is necessary to run the 2nd wire through some typenof.resistance(ie the dash warning light). If u don't, it will burn up the alternator regulator. Here is the pigtail for the alt. It has 4 wires:
http://www.amazon.com/gp/aw/d.html/r...7?a=B000C9QDR8
All I can tell you is the schematic I found says one wire. If yours has one wire but you think it should have more, then I guess you need to keep looking.
Do u know if the 02 has a cruise control light that turns on when the system is in operation? When my cruise is working and I am driving down the highway with it, I don't have any lights on my dash telling me the cruise control is in operation. THIS IS THE ONLY CAR I HAVE EVER OWNED THAT DOESN'T HAVE A CRUISE LIGHT. I can't believe it came without a cruise light. Even my 1979 Chevy p/u had a cruise light.
Thanks for the owners manual. It didn't say one way or the other about a cruise light. I can't see a 99 SE having a cruise light and an 02 not having it. Do u have 1 one? If so, is it located at the top of the cluster just to the left of center?
There's a diagram of the instruement cluster in the Owner's Manual, and it shows and Manual, which you claim you did see on a 99 SS.
I just took a look at the 99 manual and although they don't show a cruise light, this one definitely had because the guy and myself talked about it. I also remember it being hard to see because the sun was setting and coming in the car hitting the cluster.
I'm a little confussed by this whole line of questioning. You've been told that you have a one wire alt., which by the way is very common in modern vehicles. But you don't seem to want to believe anyone. I just spent a few minutes going through both owers manuals (99 & 02) and neither have "cruse control lights", which you also don't seem to want to believe, either!
Gtpguy
01-26-2015 04:50 PM
fpete1992
12-11-2014 03:51 PM
Sarahrope64
11-27-2014 11:17 AM
