***VIDEO***New motor build problem...Need some input!
Old 03-26-2016, 09:34 PM
Stephen68's Avatar
Hello, can someone please give me some input and suggestions....Heres the deal. The 95 lt4/lt1 has just been rebuilt. New valve seals, pistons, crank, etc. CC503 cam, Pace Setter long tubes. Other than the heads being reworked and bigger springs for the cc503 and long tube headers the motor is stock. The car starts good and runs/idles good but has this awful gas fume exhaust smoke coming from it. No SES codes and temp runs normal. It just smokes really bad, whether just idling or when the fuel is pushed. I have checked all the sensors and replaced the o2's with Delco. Also, the car seems to have a tiny bit of a miss when i hold the rpm around 2k steady, i can feel it in the steering wheel. All plugs and wires are new also with no pinched wires. Can anyone please give me some suggestions as to what it may be....The more you push the gas pedal, the more smoke......
https://www.facebook.com/AwesomePossum68
Stephen68 is offline
Old 03-27-2016, 12:44 AM
Stephen68's Avatar
Re: ***VIDEO***New motor build problem...Need some input!
Actually i just got to thinking...I have deleted the smog and EGR plus i have no tune with this new cam and bolt on's.....Could a tune be whats causing this problem or rather a lack of a tune?
Old 03-27-2016, 04:11 PM
RUDEDOG's Avatar
Yes you must have it tuned for that cam
RUDEDOG is offline
Old 03-27-2016, 06:33 PM
Stephen68's Avatar
Thanks RUDEDOG, That is the same conclusion I have also come to after doing a lot of research...Who would you suggest for a mail order tune?
Old 03-28-2016, 04:50 PM
RUDEDOG's Avatar
PCM For Less is who I used. No compaints. The car runs very good.
RUDEDOG is offline
Noct
05-26-2016 10:26 AM
z28cam1993
05-29-2015 10:17 PM
CheckOutMyRoost
05-23-2015 02:33 PM
95z_28_camaro_4_Ivan
05-08-2015 09:56 AM
Dave19yz28
01-26-2003 01:45 PM
Quick Reply: ***VIDEO***New motor build problem...Need some input!
