Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Stuck in Amarillo, TX
Old 07-24-2016, 02:23 AM
KYWes's Avatar
1995 Z28
Driving down the road the car quits. Try to restart and it occasionally hits but doesn't start.
Pulled codes and got DTC 18, 51, and 67
67 is for the A/C I'm not worried about that at the moment.
Ideas on DTC 18 and 51?
I read one thread about DTC 18 possible being the ignition switch. Is that correct and a good place to start.
DTC 51 can be any thing electrical possible right? Poor ground, a fluke, etc?
No other codes. When cranking the codes did not come back.
Help me get home to KY. ;-)
KYWes is offline
Old 07-24-2016, 08:07 AM
Re: Stuck in Amarillo, TX
18 is for injector circuits. I'd check injector fuses first.
shoebox is offline
Old 07-24-2016, 12:14 PM
KYWes's Avatar
Thanks, looked at all fuses in car and underhood. Everything looked good. I read a thread with a similar problem and they were looking at the ignition switch. Is that a possibility?
KYWes is offline
Old 07-24-2016, 02:01 PM
I would not think ignition switch if all your dash lights stay on. If all circuits that are supposed to have power when the switch is on actually have power, then the switch wouldn't be suspect IMHO.
shoebox is offline
Old 07-24-2016, 06:53 PM
KYWes's Avatar
Just came from checking out the car.
Ignition and Injector fuses are good. I even substituted others in to verify.
Post suggesting jumpering battery to fuses 9,10,11 had no effect.
Performed Shoebox's Optispark diagnostics. Voltages on ICM connector were good including the 1-4v AC pulse.
Voltages were good on the can sensor connector.
Didn't do everything because I had borrowed a vehicle from a hotel employee and needed to get back.
I observed the tach and I got no response when cranking. Sat at 0. Is this a reliable test? First I've heard of it.
Car is at a repair shop awaiting their attention.
KYWes is offline
Old 07-24-2016, 08:00 PM
Are you getting spark? If signals are good to ICM and you get no spark, then I would suspect ICM or coil.
shoebox is offline
Old 07-24-2016, 08:19 PM
KYWes's Avatar
I didn't get to that. I have replaced the ICM in the last few days so maybe it is the coil.
KYWes is offline
bowtieboy95
07-01-2015 06:49 AM
pete53
06-27-2015 09:08 AM
Hobbyguy
05-26-2015 02:15 PM
LimitedEd1LE
05-18-2015 01:24 PM
Quick Reply: Stuck in Amarillo, TX
