Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
No start after opti install
Old 05-06-2015, 05:25 PM
  #16
Bxlt1's Avatar
Re: No start after opti install
Still just cranks checked and double checked opti, slides in perfect every time I pulled off. Any other ideas bout this I'm clueless now lol thanks everyone for help
Bxlt1 is offline
Old 05-22-2015, 03:03 AM
  #17
slcortez77's Avatar
I'm having the same problem. I went to change water pump and decided to put new cap and rotor on. So I put it all back together and it has spark but doesn't start. Well decided to get 3 different caps and rotors and after putting and all of them taking down and putting it together each time double checking everything and I'm still without a car so if you have any clue I could use the help too. Would really appreciate it
slcortez77 is offline
Old 05-22-2015, 08:45 AM
  #18
If you only changed the cap/rotor, you should not have affected the signals from the optical cam position sensor. Since you indicate you have spark, the signals are reaching the PCM, and then the ICM.
Where did you check for spark? At the coil wire? At the individual cylinders?
Did you plug the coolant temp sensor back in after changing the water pump?
Have you scanned it for codes? ..... checked the fuel pressure?
What year is the car? Always required, since their are differences from year to year in the LT1's.
Injuneer is offline
Old 05-27-2015, 05:00 PM
  #19
Bxlt1's Avatar
Still same bout to button this car up and kid rid of it,gonna give it another once over as I still can't get this running.still cranks and cranks no combustion.
Bxlt1 is offline
10-31-2016 11:09 AM
Alex Barnes
01-24-2015 10:21 PM
Oncomingstorm22
01-22-2015 07:15 PM
thenewkid
11-27-2014 09:41 AM
Quick Reply: No start after opti install
