After a year its almost done!
Old 03-18-2015, 11:18 AM
95maroboi's Avatar
. 385 cubic inch lt1 195cc afr heads hand ported (297/240) Custom blower cam 223/235 .620/.630 114 lsa. Vortech ys blower (15-16 psi) after cooler with methanol injection. I'm hoping this thing makes some power ! I plan on upgrading the fuel system to run this beast on e85
95maroboi is offline
Old 03-21-2015, 09:41 PM
BlackbirdWS6's Avatar
Re: After a year its almost done!
Should make some good power. When does it hit the rollers and the track?
BlackbirdWS6 is offline
Old 03-22-2015, 11:03 PM
95maroboi's Avatar
It should be tuned in the next couple weeks but for aorund 8 psi only to break the engine in.I need to upgrade the fuel system for the 15 lbs.Im only running 60 lb injectors at the moment and a single walbro 255 pump with a hotwire kit.Im gonna be trying out the 80 lb high impedance injectors with twin intank pumps eventually
Old 03-26-2015, 01:52 AM
97WS6SCharged's Avatar
The 80 lb Siemens injectors idle nicely. Run them in my DD Camaro without issue.
97WS6SCharged is offline
Old 03-31-2015, 08:57 PM
87Aerocoupe's Avatar
^^^ where did you get your 80# Siemens from and are they high impedence
87Aerocoupe is offline
Old 04-02-2015, 04:01 AM
Yes, they are high impedance. @ 58 psi they flow roughly 96 lbs/hr (408 LS1 application).
Fuel Injector Connection Store
Old 04-12-2015, 12:29 AM
Thanks Chris I'll be picking those up, they look taller than the normal LT1 injectors, will they plug n play on my 97 SS?
Old 04-19-2015, 05:46 AM
They are an EV1 injector so they should be a direct replacement for the LT1. They are just thinner. You can double check with FIC though to be sure.
Old 06-07-2015, 12:18 PM
95maroboi's Avatar
Just got the car back from the machine shop and they did a ****ed up job on it so its looking like the motor has to come back out and be fixed by then.I got the car back incomplete without them installing the reservoir for the aftercooler (they said they didnt know they had to do that) even though all the parts were with them the whole time to do it.The engine has coolant or water mixed in the the oil.The car hasn't even driven 1 mile and everything was brand new i gave to them to build the motor with.They gave me a 3-4 mounth turn around time and i received my car a year and 2 months later incomplete with problems.Dont ever take your car to Robs Auto machine in Hayward, california.There highly talked about on forums but after doing business with them i dont see why anyone would want there car there.Ill be calling them monday to make sure they fix there **** up.I Paid 5200 dollers and 4200 of it was for labor and the car isnt even complete.What a joke
F'n1996Z28SS
08-23-2023 11:19 PM
10-31-2016 11:09 AM
meissen
06-01-2015 07:59 AM
capebuf
01-13-2015 07:22 PM
ChrisFrez
12-28-2014 02:25 PM
Quick Reply: After a year its almost done!
