What is wrong with stock shifter T56
Old 07-28-2015, 07:02 AM
Z28-50's Avatar
Considering a new shifter, my stock shifter is worn. If you see how these are built inside the ball is slightly loose in cup.
What is so wrong with the stock shifter if it is a brand new unit other than a long throw. If you want more pressure for the shift feel Hurst replacement springs can be used.
It just seems like such a simple design what makes the aftermarket shifters that much better?
Z28-50 is offline
Old 07-28-2015, 08:00 AM
Re: What is wrong with stock shifter T56
In addition to shorter throw, they get rid of the big rubber bushing that isolates the stock stick from the shifter. Better centering, more precise feel, and several incorporate stops that prevent overshifting.
Injuneer is offline
Old 07-30-2015, 02:26 PM
BandDirector Blk98ZM6's Avatar
All true and aftermarket shifters usually just "FEEL" better too. However, there is one drawback to losing the rubber bushings, some aftermarket shifters gain a slight rattle at WOT. I know my SLP Hurst shifter rattles. I used some dynomat on the stick and base to try and settle it down a bit. It helps a little, but just be warned that a slight rattle will be normal with some aftermarket shifters.
BandDirector Blk98ZM6 is offline
Old 08-07-2015, 01:22 AM
Fatdog2's Avatar
I went to the Hurst website and they recommend replacing the linkage with the new Hurst shifter,so no more missing the 3rd gear miss shift.Hope this helps.
Fatdog2 is offline
ch3vyb1gbl0ck
Classic Engine Tech
10-23-2023 08:07 PM
canbaufo
05-25-2015 12:01 PM
nikolt1
02-27-2015 09:10 PM
MyShibbyZ28
02-14-2015 12:05 PM
Quick Reply: What is wrong with stock shifter T56
