LT1 vs LS1 4 Channel Rears
Will a guy have trouble swapping an LT1 4 channel into an LS1 4 channel car? I understand the reluctor rings on the axles have different tooth counts but I don't know that the traction control system cares. And I know I need to swap backing plates and such but the traction control differences have me wondering. For some reason I have come across more 4 channel LT1 rears recently than LS1 in 3.42 and I'm not ready to drop the coin on an upgraded just yet.
Re: LT1 vs LS1 4 Channel Rears
The axle shafts are slightly different lengths. You should swap them, and all brake parts, if you use your LS1 brakes. Your LS1 probably has a Torsen limited slip and the LT1 has an Auburn limited slip.
Yeah I understand all of that. I was only wondering about traction control compatibility. Unfortunately, I cannot reuse my old axles since they are so badly pitted.
10-31-2016 11:09 AM
