Do I need 4.10 gears?
Re: Do I need 4.10 gears?
Wow 400 rwhp thats awesome. As far as gears that depends on how you drive it. If you like to cruise I would go with 3.73 if not then go with 4.10 or higher. Im not sure about 4.56 I dont know anyone with them. If you search theres formulas out there to estimate rpm at a given speed in a given gear.
Originally Posted by Kurt Crosbie
You know I can't let out that kind of info...
Jason
Originally Posted by mebanditws6
Good luck making 400rwhp with the CC305 cam unless you get some aftermarket heads like AFR's that flow around 300 on the intake side. Why not get a GM 847 with that forged rotating assembly? Seems like a waste to me.
Jason
Jason
There are calculators to figure this stuff.
https://www.camaroz28.com/calcs/index.shtml
has lots of useful calcs.
I figured 4.10 was a little tall and would force me to a 28" tire.
It depends on where your engine's red-line is going to be. For a relatively stock car (~6000 rpm red-line) running 26" tires, 4.10's are the perfect ratio IMO.....you end up crossing the line between 5500 - 6000 rpm (running over 100 mph, but not much more than ~110 - 112 mph).
If you're making ~400 rwhp, then you'll be doing more than ~110 mph, but chances are your engine's red-line would be higher (probably ~6500 rpm at least? ) which allows more speed in top gear (upwards of ~120 mph). Any faster, and yeah, you'd need 28" tires, or a higher gear ratio.
Try out this calculator.
Drtryder
04-22-2015 04:17 PM
