T-Top vs Hardtop
Old 03-21-2013, 12:11 PM
stngh8r's Avatar
T-Top vs Hardtop
OK. #1. I prefer a hardtop
BUT, is there really that much difference in weight?
stngh8r is offline
Old 03-25-2013, 04:34 PM
Super Moderator
JakeRobb's Avatar
Re: T-Top vs Hardtop
I believe the T-top option adds 12 pounds relative to an equivalent hard top. I suppose it's worth noting that all of those 12 pounds are at the very top of the car, so it has a relatively high impact on the car's overall center of gravity.
Emphasis on "relatively" -- after all, it's less than half of one percent of the car's total weight.
JakeRobb is offline
Old 05-07-2013, 10:11 AM
96 Z 28's Avatar
Probably not a huge weight issue, but the difference is structural integrity....
T-Tops/Convertibles are typically prone to body twist unless they have additional support structure, and then the weight comes into play.
96 Z 28 is offline
Old 05-07-2013, 12:27 PM
68 RS/SS Ragtop's Avatar
I'm assuming this is drag racing only because of the the thread? Shock tower braces really help either HT or TT on roadcourse. If you are just using the car to race- HT is the way to go. Not sure about the added weight of a TT though. Some 3rdGens have glass or lexan tops. The lexan tops are very light, about 1/3rd the glass top. I have a set of each for my 3rdGen.
I did add sfc's to stiffen the TT body, but went with tubular lca's, torque arm, and smaller torque converter to save weight in the same area as it was added. All depends on what you want to do with the car- if you only race it- then HT, if you DD it and enjoy the sun, then you can do other things to make up for the weight.
68 RS/SS Ragtop is offline
Old 08-17-2013, 09:47 PM
Mr99SS's Avatar
hard tops don't rattle as bad or flex when going sideways up steep drives
Mr99SS is offline
Old 09-08-2013, 09:55 AM
Good reference on option weights, which confirms the TT adds 12.3#:
Camaro Technical Database
Option weights for 1995 models
The following weights were taken from the 1995 MVMA specs. (All weights in pounds). Thanks to Dave Emanuel (DFE1@aol.com).
Curb Weight Shipping Weight
Camaro coupe 3251 3171
Camaro convertible 3342 3262
Z/28 coupe 3390 3310
Z/28 convertible 3480 3400
Differential Weights of accessories
6-way power seats 7.9
Remote lock control 0.4
Power door locks 1.8
Power Windows 2.7
Remote trunk release 1.3
Rear floor mats 1.8
Body side mouldings 1.8
T-Tops 12.3
Fog Lamps 2.7
Rear defogger 0.4
Air Conditioning w/ V-6 42.3
Air Conditioning w/ LT1 48.9
Sunshades 2.7
Electric sport mirrors 0.4
Cruise Control 4.4
LT1 compared to 3.4 V-6 112.0 (with 6-speed)
LT1 compared to 3.4 V-6 71.8 (with automatic)
3.8L V-6 over 3.4 37.0
Auto Transmission 41.4 (with V-6)
Auto Transmission 84.7 (with LT1)
1LE 7.0
Bose Speakers 7.0
AM/FM w/CD 0.4
By the time you make enough power to make chassis flex a significant issue, you'll be required to install a roll bar. Integrate the roll bar with SFC's and the TT will be rock solid. A buddy took a 30th SS convertible into the low 8's with a 1,350 HP blown 383, and there were never any signs of stress, given the presence of a well-designed, NHRA-certified cage.
Injuneer is online now
Old 10-02-2013, 10:39 PM
timelord's Avatar
Daily Driver T-TOP,comfort important. Frame connectors,lca-tubular K member,6 point roll bar,1,47-1.50 60 ft,4200 runs,NO problems!!
timelord is offline
Old 10-03-2013, 06:58 PM
Mr99SS's Avatar
wish I could get my 60fts that low my best is 1.55 with 275/50 dr,s
Mr99SS is offline
Old 10-03-2013, 09:33 PM
timelord's Avatar
I am running Hoosier slicks so you are even or better with real slicks!!
timelord is offline
Old 10-03-2013, 09:55 PM
Mr99SS's Avatar
I have 275/60's now but converter is **** went 1.66 with a 10.97@ony 119
Mr99SS is offline
Old 10-03-2013, 10:01 PM
timelord's Avatar
Hella Nice MPH !!
timelord is offline
Old 05-22-2014, 03:25 PM
Cam's maro's Avatar
I have been at the track to witness a high speed
T-Top ejection on a X275 Trans Am....Not pretty.
Cam's maro is offline
AviatorDave
12-19-2016 06:35 PM
Z Power
09-19-2015 11:19 PM
scottcba1
09-08-2015 09:52 AM
realistyc
07-28-2015 07:32 PM
Quick Reply: T-Top vs Hardtop
