New best 60's
Old 11-13-2009, 09:12 PM
DarkHorse's Avatar
New best 60's
Haven't posted to the CZ28 community in a while - just a quick update.
Went to the track last Sunday and ran some new best 60's - this is after we squared the car and set the pinion angle to -2.5
http://videos.streetfire.net/video/D...n-1_718074.htm
1.48
1.49
1.50
ET's were 10.65, 10.83, 10.74 - they were scattered because I was working on shock settings.
Heading out this Sunday to hopefully beat the 10.57 best that it has run.
DarkHorse is offline
Old 11-13-2009, 11:58 PM
richeez 94Za4's Avatar
couldnt see the video. what were your 60ft time before you made the pinion adjustments? What was the angle before you adjusted it to -2.5? and finally what tires are you using? I have been having a hard time hooking up also.
richeez 94Za4 is offline
Old 11-14-2009, 08:46 AM
DarkHorse's Avatar
Pinion angle previously was +4 (was way off) and the car would cut 1.55 60'
I run M/T ET Drag slicks at 14lbs of air.
The car is a fox body Mustang.
My old Z28 would cut 1.61 60's on BFG Drag Radials - suspension mods were BMR lower control arms and comp engineering 3 way rear shocks.
