My First 12 sec pass
Old 04-13-2010, 10:09 PM
9sevenZ's Avatar
heres the vid link
http://www.youtube.com/watch?v=N3xrMN4poVw
i know i just barely cracked a 12 but it felt damn good and i wanted to share
this was at LVMS (2100ft) on the 9th of april
9sevenZ is offline
Old 04-14-2010, 06:47 AM
Moderator
AL SS590 M6's Avatar
Good job. Now share the time slip or the numbers from the slip.
AL SS590 M6 is offline
Old 04-14-2010, 10:48 AM
Mikes 1994 z28's Avatar
Cool! What kind of tires were you running?
Mikes 1994 z28 is offline
Old 04-14-2010, 11:04 AM
bkpliskin's Avatar
Nice work!
If I may ask, with no disrespect intended.... What happened to your trap speed? 103 with full bolt ons and a cam?
bkpliskin is offline
Old 04-14-2010, 11:21 AM
BC2002SS's Avatar
nice, I was stuck on 13.00 for around three trips to the track.
BC2002SS is offline
Old 04-14-2010, 03:36 PM
9sevenZ's Avatar
@ ALSS590 I'll grab the numbers when I get home later :-)
@ MIKES 1994Z28 the tires are Hoosier 275-15 drag radials
@ bkpliskin I was thinking the same thing, I've trapped at 104 before, maybe it was the weather, not sure. Tracks at 2100 feet and the DA was almost 4k that night. But yeah seems kinda weak..any ideas?
9sevenZ is offline
Old 04-14-2010, 06:59 PM
HardcoreRM125's Avatar
When's the last time you did a tune up?
What does the MadZ28 tune have you shifting at?
There's a lot of little things that can add up to cost you some MPH in the 1/4.
Your car got some miles on it - how old is the Opti (keep in mind - the cap and rotor are in there ...), what kind of fuel are you running? Any knock retard? If the tire pressure is too low, you will still maybe hook but it has a lot more parasitic drag and will lower 1/4 e.t. & mph.
Just some things to consider.
Other than that - congrats man. 13 year old car, with 160,000+ miles, stock short block, and shes running 12's in full street trim.
HardcoreRM125 is offline
Old 04-14-2010, 10:13 PM
9sevenZ's Avatar
k so heres the time slip info
60' 1.895
330' 5.324
1/8 8.241@83.70
1000' 10.795
1/4 12.978@103.13
@HardcoreRM125 last tune was right after the cam, and the opti has about 15k on it (not sure of the make couldnt find any GM numbers on it)
shift points are at "+400rpm from stock"....thats what the tune sheet says
oh and my left header collector was hitting really hard on the trans tunnel brace on accel and launch (potential knock retard perhaps??)
oh and i had the tire psi at 18lbs
9sevenZ is offline
Old 04-14-2010, 10:31 PM
6SpdLT1Z's Avatar
I kind of feel like your car should have a little more in it as well. I think it should be trapping 105+ I trapped 102-103 with shorty headers in my 6 speed car. Granted your hooking more off the line, I think you should be closer to a 12.5-12.7@105-108. Any idea what the DA was that night?
Congrats on the 12 second pass though!
6SpdLT1Z is offline
Old 04-14-2010, 10:48 PM
9sevenZ's Avatar
track elevation is already at 2100ft and the DA that night was almost 4000
9sevenZ is offline
Old 04-14-2010, 11:27 PM
dragginS10's Avatar
shouldn't you not do a burn out unless your on slicks..I heard it actually makes things worse if you do on anything but slicks. Im not sure though.Also im curious of why only one tire is spinning. Sorry i dont mean to be rude im just curious
dragginS10 is offline
Old 04-15-2010, 06:44 AM
Moderator
Originally Posted by bkpliskin
Nice work!
If you were to correct his MPH and ET to zero DA from his 4000' DA the numbers would be good.
Old 04-15-2010, 08:22 AM
bkpliskin's Avatar
He hadn't posted his DA when I wrote that. That is very true, he took a bit of a hit there.
Old 04-15-2010, 06:37 PM
That track and DA just suck lol.
Go somewhere LOW on a night with good air. You have a solid 12 second car.
Old 04-16-2010, 10:21 PM
fasteddie94's Avatar
That's true for street tires but a drag radial is alot closer to a slick that a street tire. Drag radials require a little bit of heat.
fasteddie94 is offline
Quick Reply: My First 12 sec pass
