how to improve?
Old 06-18-2009, 12:01 PM
reamo04's Avatar
how to improve?
http://i39.tinypic.com/wn3hu.jpg
talked to a friend of mine, and he told me that it looks like it moves out great on the low end (i agree), but it needs to get new heads and increase the top end.
Car is basically cam only, bolt on 211/219 LPE cam with 1.5 RRs.
reamo04 is offline
Old 06-18-2009, 06:40 PM
Z-RATED94's Avatar
M6 or auto? What rear gear and where do shift at? Does bolt ons mean headers too?
Z-RATED94 is offline
Old 06-18-2009, 09:29 PM
reamo04's Avatar
has mid length pacesetters, y-pipe with a muffler at the end of the y-pipe, CAI, ported intake, auto, 3600 stall, 3.91 gears
reamo04 is offline
Old 06-19-2009, 05:43 PM
Z-RATED94's Avatar
What muffler? Can you pull it at the track? Maybe put a little money into the heads, basic port clean-up, pocket porting and a good valve job. Maybe have them milled and use the Impy gasket. Why not invest in some 1.6 roller rockers too. Car been tuned?
Old 06-19-2009, 11:47 PM
reamo04's Avatar
car has a glasspack at the end of the y, its not hurting it any
we're trying to keep it cam only, so trying to stay away from the heads, and car has been tuned. trans just pretty much blew up tonight, so, were wondering if getting that done will help.
reamo04 is offline
Old 06-21-2009, 09:57 PM
AutoRoc's Avatar
Sounds like it runs well and it 60fts good.
TransGo shift kit should help along with making it full manual.
It's picking up 20.82 in the last half of the track. There might be more power in the tuning or maybe we can hope the trans was eating itself on that pass also..
Pull more weight out of it, Drag rims/tires with skinnies up front and Hoosier drag radials out back can be an 80+lb reduction.
Goodluck!
AutoRoc is offline
Old 06-21-2009, 10:21 PM
reamo04's Avatar
well guys, we are putting in a cc503 cam, 4.30 gears, and a th350.
We shall see how it works out, the gears will get us 112 at the stripe at the limiter in 3rd. See if we can break into 11's with it.
reamo04 is offline
Old 06-21-2009, 11:28 PM
AutoRoc's Avatar
You'll need a new converter also if you go to a th350.. will you do something closer to a 4000 stall?
AutoRoc is offline
Old 06-22-2009, 12:10 AM
Z-RATED94's Avatar
I thought you meant muffler not glasspack. Sounds like you have it all worked out. Good luck.
Old 06-22-2009, 12:31 PM
reamo04's Avatar
waiting on ATI to call me back. The guy I was supposed to talk to is on lunch lol. I was thinking a 3800, maybe I will just go 4000.
reamo04 is offline
Old 06-22-2009, 06:22 PM
reamo04's Avatar
well, ATI never called back, so I am going to go else where.
Started the cam swap today
reamo04 is offline
Old 06-23-2009, 07:03 PM
AutoRoc's Avatar
A lot of people are still talking about PTC down south and Lenny @ UCC(ultimate converter concepts) for good converters... I've never owned either but goodluck!
AutoRoc is offline
Old 06-23-2009, 09:38 PM
reamo04's Avatar
yeah, ive talked to lenny a couple times.
reamo04 is offline
Old 07-05-2009, 08:44 PM
reamo04's Avatar
well guys, installed the cam, a 4,000 stall with a th350, and a nitrous setup. I think i may have taken a step in the right direction
reamo04 is offline
NewsBot
09-14-2015 08:50 AM
CARiD
09-07-2015 08:21 AM
Bails098
08-17-2015 05:15 PM
karpetcm
08-14-2015 03:02 PM
Boss002
07-09-2015 03:33 PM
Quick Reply: how to improve?
