Need your best opinion
Old 05-21-2013, 01:57 AM
Superman94's Avatar
Alright I understand everyone wants a "wheelstand!" And I understand that's not what you want coming off the line. But as of right now we're trying to get my car out there and advertised. And no one wants to see a picture coming off the line like a 4cylinder... They wanna see the tires in the air. So my question is I have a 94 Z28 LT1. The car is built up well into the 600's, has 3:91's, 2800 stall, Edlebrock front struts and all other suspention is stock. What can I do to put it in the air a good 6-8inches?
Superman94 is offline
Old 05-21-2013, 04:10 PM
Steve69SS396's Avatar
Re: Need your best opinion
Horsepower means nothing if it doesn't hook. What ET and MPH does the car run? It would be helful if you post a timeslip with all the incrementals: 60 foot, 330, 1/8, 1,000 foot, etc.
Steve69SS396 is offline
Old 05-22-2013, 08:00 AM
kazman's Avatar
+1 on getting the car to hook. Slicks and supension. Sub frame connectors, lower control arm relocation brackets, Wolf rear sway bar, 8 point roll bar. This will tie the car together. IMO the car will need to leave harder than what the 2800 stall will allow. Converting to a t350 or t400 with a trans brake may be required.
kazman is offline
Old 05-30-2013, 05:45 AM
bubba4's Avatar
I agree with Steve and Kazman , I'll add a -2.5 deg. pinion angle and the right shocks really helps too.
bubba4 is offline
Old 06-04-2013, 12:42 PM
Super Moderator
JakeRobb's Avatar
Any front weight reduction you can manage will also help.
JakeRobb is offline
Old 06-12-2013, 07:03 PM
cnorton's Avatar
You have a PM. Apparently, I am not cleared to attach pictures. Basically, you need more gear and more converter.
cnorton is offline
Old 06-17-2013, 04:00 PM
You can only include pictures by entering the IP address for where they are located on the internet. You cannot attach the actual photo directly to a post. No one can.
But.... CZ28 provides you with the ability to add an album to your profile, upload the photos there, and then you can link them.
https://www.camaroz28.com/forums/sit...28-com-699204/
Injuneer is offline
Old 09-26-2013, 08:36 PM
Mr99SS's Avatar
steve u got cowl tracs they will make it wheel stand or just tote tires. Ive driven my brother BB vega wheel stands aren't fun ... u cant see if ur going to the guardrail or straight. best 60ft I got was a 1.32 with the back tires.
there is a huge diff in wheel stand an toting the tires btw
Mr99SS is offline
Ks0209
10-01-2015 07:32 AM
drt
09-27-2015 04:39 PM
SEOJustin
09-24-2015 04:39 PM
jackpawt883
07-31-2015 08:15 AM
birdblack
07-08-2015 07:23 AM
Quick Reply: Need your best opinion
