Transmission Tuning Tutorial
Old 06-15-2010, 08:43 PM
  #76
93v8clone's Avatar
i dont have a r.p.m window .its only by speed , i have a performance column and a normall column both have a w.o.t speed rating . bein a camaro and i dont have a perf shift button i should use the norm mode im guessin
93v8clone is offline
Old 06-15-2010, 09:47 PM
  #77
aifilaw's Avatar
... you will note that there are two different tables, kickdown mode by RPM, and kickdown mode by mph... both of these must be met in order to shift... chances are your mph are just fine and the rpm table is too high, it may be the other way around, but not usually.
as far as the other tables regarding normal mode, performance mode and cruise mode... yes you want to do normal mode.
aifilaw is offline
F'n1996Z28SS
08-23-2023 11:19 PM
thenewkid
04-12-2015 07:42 PM
PublicEnemy1
04-07-2015 12:21 PM
Jazsun
12-29-2014 12:14 PM
Quick Reply: Transmission Tuning Tutorial
