radiator fan always running
Old 04-22-2011, 12:32 AM
  #16
Stealth_Z28's Avatar
Re: radiator fan always running
OK, I didn't get to do much testing yesterday, but the volt test on the temp wires came out good at 5 volts. Today I cleared the codes, started the engine, the fan did not run. According to the gauge the water temp hit around 225 and the fan actually did not come on. I don't know if I need to run/drive even longer and get it really hot or I may now have a (new) problem. Also, I got a new code now, code 34 (no more 14 and 42).
To answer knucklehead27's question. I believe we concluded the fan temp sensor is just above the water pump, two wires which are yellow and black. Depending on how things go with further testing, I may end up with a problem like knucklhead's even though I have already changed my sensor....
Stealth_Z28 is offline
calaban
05-18-2020 06:43 PM
10-31-2016 11:09 AM
4586
12-31-2014 02:21 PM
07-04-2005 05:00 PM
Quick Reply: radiator fan always running
