24x conversion on 94 with OBD1 connector
Hey peps!
I am installing a 24x conversion on my 1994 LT1 Z28 and started to think about what tuning software to get for the LS1 PCM. It then hit me that my 94 has an OBD1 connector under the dash and I will need an OBDII connector to plug into now.
Anyone have any info where I can read how to do this or what my options are?
JD
JD
Re: 24x conversion on 94 with OBD1 connector
Hey peps!
JD
JD
"PoorMan" has not signed into this site since 2014.
The conversion wiring harness available from the two possible sources will address the wiring. Very easy to replace your OBD-1 connector with an OBD-2 connector. The conversion harness supplier should be able to supply the required part.
When you said you had the same problem asked about by PoorMan, I assumed you were asking what you had to do about having a 12-pin connector, and needing a 16-pin connector. But appears you already have the harness and the 16-pin connector, so my response was virtually useless. I have no idea of what the pinouts are on an LS1 PCM.
Sorry about that.
Sorry about that.
autoxr166
09-25-2015 04:21 PM
