81 trans am turbo
301 is usually tossed in favor of a 400 or bigger Pontiac or Olds or a 350 or bigger Chevy. The deck height is lower on 301s, so while perf heads will bolt on, there is no intake available that would make the swap worth while. And the better heads have bigger chambers so compression ratio would drop even lower. etc, etc. That's why guys that aren't going for a full resto put their $$$ into a better engine.
Might also want to ask over at TAC: http://transamcountry.com/home/
