Autocross and Road Racing Technique There is more to life than a straight line
best way to do doughnuts?
Old 07-14-2005, 12:17 PM
CHELOZ28's Avatar
I have never really tried to do doughnuts in my car, what is the best way to learn. Also will they damage anything on my car, besides wear on my tires?
CHELOZ28 is offline
Old 07-14-2005, 12:26 PM
Z28SORR's Avatar
Re: best way to do doughnuts?
Find the biggest empty lot you can, (no light poles). Stop in the middle of it, turn the wheel full right or left and stand on it, keep turning. Watch your rpm's.
Z28SORR is offline
Old 07-15-2005, 12:56 AM
Paul87's Avatar
I'm not an expert but I couldn't imagine it being too good for your rear axle
Paul87 is offline
Old 07-15-2005, 01:31 AM
CrabhartZ28's Avatar
if the wheels are spinning alright, i couldn't imagine it being too punishing. Certainly not any worse than putting radials on a stock 10 bolt.
What RPM should you aim for?
CrabhartZ28 is offline
Old 07-15-2005, 01:45 AM
ShawnLT4Z's Avatar
i broke the pinion gear in my rear end doing doughnuts one time. i haven't done them since.
ShawnLT4Z is offline
Old 07-15-2005, 03:47 PM
Zack's Avatar
dont fully lock the wheel to the right or left
i blew my power steering pump doing them
Zack is offline
Old 07-15-2005, 07:51 PM
GT KILLER's Avatar
Soooo...pretty much it's not a great idea to do them at all then? LOL
GT KILLER is offline
Old 07-15-2005, 08:25 PM
JP2005's Avatar
i have done alot of them and have not had any of the above mentioned problems,
but its simple just turn your wheel, and have fun w/ the accelerator, do one then do another two, until you have the confidence then just make an a*s load of smoke...oh yeah and if you do it alot have some $ for tires
JP2005 is offline
Old 07-16-2005, 09:14 AM
MustangEater82's Avatar
Just turn it far, not all the way...
and generally its not a good idea to do it often but you hae to do it a few times...
MustangEater82 is offline
Old 07-24-2005, 04:33 PM
slayerxxx213's Avatar
Like some of the other guys mentioned don't lock the steering fully one way or the other, it puts a ton of stress on the powersteering pump, and it will eventually blow if you beat on it like that. But, to do a nice one, just stand on the brake, give it some gas, (enough to brake the tires loose), turn the wheel depending on how big a radius you want and let off the brake, once you start turning you should be able to turn the steering so it's like fully opposite locked and basically just drift it around in a circle. Also, once you get the tires spinning, it won't take much to keep them spinning, so you don't need to rev the crap out of the motor, but as long as your not bouncing off the rev limiter for an extended period of time it won't hurt it. Basically if you find a nice big empty parking lot where you can't hit anything and you don't lock the steering completely for an ext. period of time you shouldn't hurt anything, (don't do burnouts or donuts or anything like that over choppy pavement, you'll put lots of stress on the rear), you should be fine. Hope you got $$$ for tires though, burnouts and dougnuts can be very addictive...Good luck and have fun
slayerxxx213 is offline
Old 07-27-2005, 06:54 PM
1995greenTA's Avatar
If you get bored with the above, Find a REALLY big parking lot, get going about 40 mph, slowly start turning more and more until your *** end starts to slide out, when it does, punch it, and hold on. Ive never had any problems with doing them, except for wearing out some tires, and in the snow, I hit a curb or three.
1995greenTA is offline
Old 07-28-2005, 12:27 PM
flyinZ's Avatar
yep, just like the other guys said..but Id turn the wheel to the left, otherwise you'll get a "one tire fryer" if you turned it to the right..heh
flyinZ is offline
Old 07-29-2005, 09:29 AM
jsetzer's Avatar
There are lots of ways, one of the easiest I have found and still tasty is to buy a tube of cheap biscuits. Shape them however you want and drop them in hot oil, fry them up for a short period then brush a mix of sugar/water on them and let it dry. Tastes great and its pretty easy.
Guess I have never done a full spin in the car. I have done some 180 turns. Just don't beat on it too hard. I am going to play with a 12 bolt and some junk tires tonight, might get some video.
jsetzer is offline
Old 08-01-2005, 01:24 AM
MotorCityNova572's Avatar
lol hahahah smart A$$.....
No but me and my buddy have done them its easy...turn the wheel to the left and just let it all go.....of if your paint if its messed up and dont care about dirt or little rock chips...you always can go oin a dirt road turn leaft or right and hit the gas.....BUT if you do that JUST watch out for trees..lol
MotorCityNova572 is offline
Old 08-01-2005, 06:29 AM
wbna0149's Avatar
Totally the wrong forum for this thread.
wbna0149 is offline
Quick Reply: best way to do doughnuts?
