Tach help...
Old Mar 28, 2003 | 12:46 PM
HM Murdock's Avatar
Tach help...
What sensors control the tach? Mine is not working, and the cluster itself is not the problem, the tach is not reiciving a signal...
Also, the trip odo is not working as well...I have never seen this problem before...
Thanks...
Old Mar 28, 2003 | 01:41 PM
atljar's Avatar
I believe the tach is read as such, please anyone correct if wrong.
Their should be a white wire going from your coil to the ECM. That is the tach wire. Pin # 13, in the red connector.
I would start by making sure that it is firmly plugged in on the computer end, and also make sure it has good contact on the coil and isnt corroded.
Good luck,
Old Mar 28, 2003 | 01:51 PM
HM Murdock's Avatar
Thanks, that's what i needed. I kew that the signal comes from the opti, to the PCM, to the dash, but I didn't know which wire.
mr28
Apr 20, 2016 05:44 PM
Zee man
Feb 12, 2015 07:07 AM
ldtantlinger92
Jan 19, 2015 01:26 PM
mr28
Nov 23, 2014 11:11 AM
