How do I calculate my inj duty cycle???
Re: How do I calculate my inj duty cycle???
Originally posted by The Highlander
Datamaster is very very ackward with it... Thanks
100% duty cycle as I understand it, means that the injector is open all the time. So, anything over 100% doesn't really matter cause "open all the time" is rather self explanatory.
You generally want to stay at 80-90% but no higher. If your demands go beyond that rate, then you need a bigger injector.
-Mindgame
-Mindgame
Duty cycle is calculated by dividing actual pulsewidth by the amount of time available in two crank revolutions (the time for a 4-stroke cycle) at any particular RPM. Some available times for 2 crank revs at various RPM:
4000 - 30mS
5000 - 24mS
5500 - 22mS
6000 - 20mS
6500 - 18mS
If you were running at 6000rpm, and DataMaster showed a 17mS pulse width, your duty cycle would be:
17/20 = 0.85 = 85%
I have seen some DataMaster logs where the "duty cycle" numbers don't make any sense. I have suggested to people that they go back to TTS and ask why, but no on has done that.
4000 - 30mS
5000 - 24mS
5500 - 22mS
6000 - 20mS
6500 - 18mS
17/20 = 0.85 = 85%
Nayr
Mar 3, 2023 08:34 PM
