Simple M6 questions
Old Mar 27, 2003 | 06:06 PM
96z's Avatar
96z
Simple M6 questions
A got a couple random questions for you guys.
1. What is a throwout bearing? Is it a wear item like a clutch?
2. Can you or should you resuface the clutch side of your pressure plate like your flywheel?
3. How does the tranny mount fit on an M6, anyone with pics?
4. What does a "worn clutch" look like?
Thanks.
Old Mar 27, 2003 | 06:54 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
Re: Simple M6 questions
Thanks.
1. its the bearing you will hear when the clutch goes in. when my buddies went, you could hear it squeek everytime he went to shift. They go after a while, nothing to get worked up about.
2. You CAN resurface a clutch, thats all i know though. i dont know how well it works, cost or anything like that though
3. nope, but just search altavista's or google's images. sure you can find one.
4. a worn clutch will be smooth. My other friend missed a down shift- went 5-2 instead of 5-4. luckily his clutch sucked and it broke before the R's could get up. it was smooth like glass. That is an extreme, but it will be smoother. it will look worn. kinda hard to explain.
here is a pic though
http://www.millionauto.com/Help/clutch/WornD.jpg
hope this helps
Old Mar 27, 2003 | 07:21 PM
96speed's Avatar
Pimp dog Matt: Normally you replace the pressure plate when you install a new clutch. A worn clutch will have a "glazed" kind of look to it. I'm sending you a pick of a TOB. The TOB's job it to supply the clutch fork a place to pull/disengage the PP by pulling the pressure plate up/off the clutch disc(s). (LS1s use a push-type PP).
HTH!
Ryan
Old Mar 27, 2003 | 07:34 PM
viperkiller's Avatar
if replace the clutch replace pp often the pp looses strength and couses cluth to slip so dont chance using old pp
Victor Lamb
Aug 26, 2017 02:52 PM
Hurin
Dec 13, 2014 07:38 PM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
Geoff Chadwick
Jul 31, 2002 12:07 PM
