replaced tbody set ses light
i just replaced my stock throttle body with a ebrock 58mm
and my car is setting a ses light does anybody out there know
why its doing that i dont have access to a scan tool till tommorow
so i dont know the code its throwing but i was just wondering if anybody else had had this problem
i double checked all my connections and the car runs fine through out the rpms but the light is glowing right after you start the car
like something is unhooked but nothing is
can anybody help
can anybody help
Are you sure you reconnected:
-TPS sensor
-IAC motor
-IAT sensor
-MAF sensor?
Did you check the TPS voltage after install? Did you check the IAC counts after install? Does the idle speed seem correct?
Did you spill any coolant on the Opti?
-TPS sensor
-IAC motor
-IAT sensor
-MAF sensor?
Gtpguy
Jan 26, 2015 04:50 PM
squarehead
Jan 15, 2015 07:02 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
