Headlight not opening on TA
Old Mar 27, 2003 | 11:56 AM
Njgunslinger's Avatar
Has anyone had this problem with their Headlight not opening or closing on their Transam. I have a 2000 TA and the passenger healight keeps not working. I have at the dealership for the third time and they are replacing the module again, says they might of had a bad bunch, sounds lik crap to me.
Old Mar 27, 2003 | 02:12 PM
fbird95's Avatar
I only went through one on each side. I know know what you mean about dealerships telling you about a bad batch through. I went threw 6 ac check valves in a 6 week period. They told me it must be a bad batch. How about you get me one from a different good batch.
Old Mar 27, 2003 | 06:20 PM
SunsetWS6's Avatar
Wink
My driver side light motor burned out in less than a year. I've had 3 4th gen birds & this was the 1st time I had a problem. Good thing for warrenty. It's worked fine since they fixed it.
Old Mar 27, 2003 | 11:50 PM
barkerg's Avatar
AC check valve?
Where is this located? The reason I ask is because sometimes my AC will not work unless I tap this switch on the AC tube that has the charge port.
Old Mar 28, 2003 | 09:33 AM
fbird95's Avatar
The ac check valve controls the vents and which one the air blows through. If you standing in front of the car it will be on the left side near the firewall. I looks like a black T that has a round barrel on it. Its no more than two inches big. They need to make a metal one or use plastic that doesnt continually fail.
NewsBot
Sep 30, 2015 04:20 PM
Greg88
Sep 20, 2015 07:14 PM
Tarizza
3rd Gen / L98 Engine Tech
Sep 20, 2015 03:26 PM
Toxintwins
Sep 11, 2015 11:13 AM
jackpawt883
Sep 10, 2015 08:53 PM
