Can a .5 OD be installed in a 93 T56
Old Mar 27, 2003 | 09:12 AM
93Z4ME's Avatar
I was curious if a .5 6th gear could be installed in a 93 T56 in place of the .62. That way I can keep all of the nice low gear ratios and yet have the better OD.
Old Mar 27, 2003 | 09:23 AM
GREGG 97Z's Avatar
Gas is getting pretty expensive out in CA I hear
94 and later use a .5 6th so I would think it could be used in a 93, but I've not heard of anyone changing ratios. It seems like quite a bit of work to tear into the trans for such a little gain in ratio but maybe the gas savings would make up for it .
Old Mar 27, 2003 | 09:39 AM
teke184's Avatar
you'd only be dropping about 20% rpm's at typical cruizing speeds...so basically rebuilding a tranny for 200 highway speed? doesn't sound very economical to me...
Old Mar 27, 2003 | 09:52 AM
93Z4ME's Avatar
I would only do it if I had it out anyway (during a cutch job), and if it was reasonable cost wise during a refresh/rebuild (I've done some manual rebuilds before and could handle dissasembly and changing some parts and gaskets.)
Old Mar 27, 2003 | 04:35 PM
Turbo6's Avatar
Unless you have aftermarket gears, the '93 model cars came with 3.23's from the factory instead of 3.42's like the '94 and up, so that .62 6th gear coupled w/ the 3.23's is about the same as the 3.42's coupled w/ the .5 6th gear. Any more overdrive and the car would probably lose fuel economy from lugging the motor. You should be able to do over 80mph @ 2k rpm as it is.
Old Mar 27, 2003 | 04:43 PM
Red_94Formula's Avatar
Yes you can. There was also a guy who made custom t-56 gears too, but I dont know who.
Old Mar 30, 2003 | 10:46 PM
INFERNO's Avatar
I have a 93 Z with the 3.23 gears and a 95 T56 and I am just waiting to see the rpm's I turn at 80.
Nov 18, 2023 07:21 PM
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
Sergio
Jan 27, 2016 04:27 PM
Jason Short
Jan 19, 2015 06:34 PM
