Where to go for cheap editting and cables?
Old Mar 26, 2003 | 07:30 PM
94FlamdS10Blazr's Avatar
I need to eliminate my EGR, vats,air ,and maybe do some tweeking while Im there. I need the cables first and editting next. I talked to a guy that said he can do it, but I cant find his email and I need a cable from another guy I cant remember.
I dont want the $90 AKMcables. I need something cheaper and I will solder onto my wires without a problem. Hell I did the motor swap using a stock Caprice wiring harness I think I can do this!
Old Mar 26, 2003 | 08:06 PM
Brent94Z's Avatar
Super Moderator
If you don't want to spend the money for a quality cable then just make your own. AKM has schematics on his website on how to make your own... or at least he used to
FWIW, I recommend just buying a known good cable from AKM.
Old Mar 26, 2003 | 08:45 PM
turbo_Z's Avatar
last i knew Andrews cables were only $65 if you dont go with that molded connector. and as Brent said you can make your own cable. Andrew can sell you all the parts to make it for maybe $35 or $40 but its a lot of work IMO. there are 2 guys that i know of who make a cables that are flash worthy and one is Andrew at AKM cables.. the other guy i think basically works with him so all the parts and prices should be the same.
Old Mar 26, 2003 | 08:49 PM
5thCamaro's Avatar
I just bought a cable from andrew for 65 yesterday. I am waiting to delivery. I am sad I will not have it before this saturday when I goto the SLP cust day in Orlando.....I need some tuning pretty bad.
Old Mar 26, 2003 | 09:19 PM
Andrew who , what where? he got a website? Also who can do the editting?
Old Mar 26, 2003 | 09:23 PM
5thCamaro's Avatar
akmcables.com
Old Mar 26, 2003 | 11:52 PM
ok i know now that Andrew is akm but wasnt there somebody else that was doing a solder-on kit without the expensive GM connector?
Old Mar 26, 2003 | 11:58 PM
turbo_Z's Avatar
www.wotelectronics.com
Old Mar 27, 2003 | 01:22 PM
Eddie95Z28's Avatar
Has anyone else had good luck with these cables. for both reading AND writing the PCM? I am going to order one if the word is good.
Old Mar 31, 2003 | 06:21 PM
anybody else know where to get the cables you solder on? I dont feel like buying the expensive GM adaptor
Old Mar 31, 2003 | 06:32 PM
turbo_Z's Avatar
if you are looking for a cable for $10 it wont happen. if you invest in a poor quality cable you risk the chance of loosing a PCM and i can guarantee you that will cost more than the small money you are tryin to save.
Old Mar 31, 2003 | 07:11 PM
no less than $90 or should I stop being a puss and get one?
Old Mar 31, 2003 | 07:15 PM
turbo_Z's Avatar
you can get a cable for $65 from either of the sites listed.
Old Mar 31, 2003 | 07:49 PM
ok i said screw it and ordered the $45 cable from WOTelectronics which is really from Steve Russ? SO I hope its on the way and I can turn my SES light off on my swap project
Old Apr 1, 2003 | 02:02 AM
HungryT/A's Avatar
As for the editing, the best and the cheapest place is MadZ28.com. Ion, the owner, is a fellow board member, too (MadWolf). He made my tuning and I was simply amazed!! Ordered the program on Thursday, got the file next day! Contact him and tell him Victor sent you
