Spark Plug Gap with P1-SC
Old Mar 26, 2003 | 01:19 AM
1995z28's Avatar
Just wondering what you guys think I should run for a plug gap with this setup:
Stock internals LT1
P1-SC 8# blower
RK-Sport midlength headers
Borla cat-back
Offroad pipe (3")
I am putting in NGK TR6 plugs, am thinking about .035" gap, what do you guys think? Am I close?
Thanks!
Old Mar 26, 2003 | 07:12 AM
1st and goal's Avatar
That's what I run for a plug gap.
Are you running a MSD 6BTM ? aftermarket coil ?
Those are some items you should consider.
I ran NGK plugs when I first put my old P600B on the car but found the gaps opened up on them and switched to Autolite 103's
Good luck,
Marc
P.S. Boost is addictive
Old Mar 26, 2003 | 11:00 AM
1995z28's Avatar
Thanks for the info Marc.
I have been thinking about the 6BTM for a while now but might have to run 'er with stock crap for now. What kind of coil are you running?
Thanks again,
Seth
Old Mar 26, 2003 | 11:26 AM
IDOXLR8's Avatar
I set mine at .032.
Old Mar 26, 2003 | 12:02 PM
Thanks again,
Seth
I'm running LS-1 coil packs on my new setup
http://www.geocities.com/marcs94z28/383coilpacks.html
Before the coil pack conversion I was using an MSD coil, MSD 6 BTM and MSD superconductor wires.
You really need to run a MSD 6 BTM to pull some timing unless you've had the PCM reprogrammed.
Marc
Old Mar 26, 2003 | 10:32 PM
1995z28's Avatar
I just gapped the plugs at .035 today, will try that. I know for one thing that I HATE changing plugs on this thing already. With the headers on it, plugs are a real b*tch to get to. Any slick tricks on changing 'em an "easy" way???
-Seth
Old Mar 27, 2003 | 11:32 AM
There's no real "easy" way to change spark plugs, you just get better at it the more you do it
Some headers are more spark plug friendly than others.
I did manage to pick up a telescoping spark plug socket that some dude made and was selling in the for sale section. That did help a CH, especially on #5
Marc
jayblev95
Jun 7, 2015 04:04 PM
markzzzz
May 8, 2015 09:21 AM
blkWidow
May 3, 2015 08:42 AM
nikko
Apr 20, 2015 07:56 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
