Does lt1 have something like limited slip differential?
Old Mar 26, 2003 | 12:26 AM
scyzoryk's Avatar
Does lt1 have limited slip differential?
Old Mar 26, 2003 | 12:49 AM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
Re: Does lt1 have something like limited slip differential?
Limited slip differential is a unit in the rear differential
Its why you you lay 2 sets of rubber down in burn out. wihtout it, you would have "1 wheel drive car." It also "slips" in a limited amound when you go to make turns (or else turns would really suck!
The LT1 is an engine.
complete opposite end of the car
Old Mar 26, 2003 | 01:11 AM
Don't Look Back's Avatar
Exactly....it's also known as "Posi-Traction". If your question means is it available on LT1 powered cars, then the answer is yes. I believe the RPO code is G80.
Old Mar 26, 2003 | 01:35 AM
treyZ28's Avatar
its standard actually on all 4th gen V8's
Old Mar 26, 2003 | 05:54 AM
scyzoryk's Avatar
....I ment if LT! cars have slip differential. I just watch Top Gear and they mention that in M5 so I just wonder if my car have it also...
Old Mar 26, 2003 | 12:21 PM
Mtrhds94Z's Avatar
If you are talking about the car in your signature you definitely have a Limited Slip Differential...
If by 'M5' you mean 5 speed manual trans.. no f body cars with LT1 motor came with 5 speeds... [ only the V6 cars had that..]
Old Mar 26, 2003 | 04:40 PM
scyzoryk's Avatar
By M5 I ment BMW M5 but you were close enough ....By the wat "Top Gear" is the best in testing sport cars!!!
F'n1996Z28SS
Aug 23, 2023 11:19 PM
guionM
9
Aug 29, 2002 01:48 PM
rpmz28
Aug 7, 2002 08:02 AM
newby
Jul 25, 2002 03:22 PM
