How great is the 460LE on Nitrous?
Old Mar 26, 2003 | 12:19 AM
Ataririder's Avatar
Lightbulb How great is the 460LE on Nitrous?
I've been using a wet 75 shot on my Impala and never had a problem so far with the tranny. I have a 2400 stall and a transgo kit installed. But I hear that the trans limit is 350lbs, is a transgo and bigger stall going to help out the life of the trans or should I expect the trans life decline? I never use nitrous between the shifts. TIA
Old Mar 26, 2003 | 06:39 AM
Derrick Redd's Avatar
I'm guessing you mean 4L60E. I spray a 150-175 shot out the hole (slicks), and through the shifts. Time in sig. Properly built they can run some good #'s.
Old Mar 26, 2003 | 10:18 AM
COMNBYU's Avatar
my buddy at GM told me that in stock form, their not designed to take that much more power than stock. i started out spraying a 100 shot on my completely stock tranny between shifts with no problems at first. then i moved up to the 150, and it slips on the 2-3 and wont actually shift into 3rd.
my car now has 104k miles and i started spraying around 95k. my buddy told me that at 100k, i should really have the tranny flushed. so in order to try and help the slipping prblem heres what ill be doing in the next couple of weeks-
1. getting tranny flushed
2. putting in all new B&M synthetic shift fluid
3. getting JET Performance Shift-Plus shift kit (consisting of a module to electronically select between different shift settings, and a valve body kit)
hopefully this will help with the shifting for a while. if not, i will be buying a new tranny soon.
jon
Old Mar 26, 2003 | 05:55 PM
Ataririder's Avatar
I heard the synthetic tranny fluid is bad to put in our trannies. I was told only use Dexton III. Synthetic tranny fluid does not have that. Also putting a shift kit like transgo on a half-dead tranny is like giving a dead person CPR. Also if you go throught the electric shift kit, it'll work the same way except the tranny will die sooner, because you;re putting too much pressure on the lines.
Does anyone know if a 4L80 trans bolt up to an LT1 or does is a TH400 good for Nitrous use?
Old Mar 26, 2003 | 06:12 PM
94DROPTOPZ28's Avatar
I'm having my trans rebuilt right now as we speak because I'm already having problems with the 4L60E, with only heads and cam so I'm gonna do a rebuild before I spray.....
Just to be safe
Old Mar 26, 2003 | 08:44 PM
OneFlyn95z28's Avatar
When built properly they will live deep into the 11s easy. I have them running 10s.
I run 11s N/A with synthitic fluid. I have a 175 shot ready to go and expect no problems with my 54K miles trans.
At 105K Miles I would rebuild it
Old Mar 26, 2003 | 09:23 PM
funina91ss's Avatar
Save your money on a rebuild..IMO you are wasting your time and money trying to make the stock one last any longer.The damage is already done
jon
Old Mar 31, 2003 | 07:06 PM
94droptopz's Avatar
DERRICK REED-- what work have you had done to your trans? im building a 396 with a 125 and really need some suggestion on my 4l60e. thanks man
Old Apr 1, 2003 | 07:48 AM
Sent you an email.
Old Apr 3, 2003 | 04:13 AM
James Krawcion's Avatar
Some of you guys must be lucky then. I couldn't keep my 4L60E on the spray without blowing it up all the time. The TH-400 does great though. It does bolt up to the enigne (whoever asked) but a mounting bracket, speed sensor, driveshaft. dipstick etc. are other issues. I really do miss having overdrive too.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
gto4u2
Mar 14, 2015 06:05 AM
alphaauto
Jan 23, 2015 07:42 AM
bandit383lt4
Dec 21, 2014 09:12 PM
