HELP! Rear end noise = No money for me.
Old Mar 25, 2003 | 07:00 PM
LOW TRAC's Avatar
Unhappy HELP! Rear end noise = No money for me.
Alright, I was sitting at a stop light by myself and launched kinda hard. I didn't feel any problem with acceleration but I heard two loud bangs and really felt those noises in the center council (sp?). At the next light I reved it a few times and then drove it home normally with no other noises. I have also been hearing a humming coming from the back of the car since I've owned it. Its not the pump cause it changes pitch with the power applied and only when accelerating and decelerating, not while crusing.
Now is my posi going out or did I screw up the ring gear or something? I dont know a whole lot about rear ends yet but this has me a little worried.
Old Mar 25, 2003 | 08:05 PM
Badws6's Avatar
If you heard it in the console I'd check the Trans mount first. I just broke mine a couple of months ago sounded like a gun went off inside the car when I broke it. 20.00 fix in about a 1/2 hour. Hope this helps
Old Mar 25, 2003 | 10:07 PM
LOW TRAC's Avatar
Hmm, that would be nice. Anybody else have a suggestion? I'll check it out when I go home this weekend but untill then....
Thanks for the info.
Old Mar 25, 2003 | 10:10 PM
LimitedEd1LE's Avatar
You might have blown your pinion bearing. But you wouldn't be able to tell unless you tore your rear end apart. I would first check the trans mount, and then check the rear end if it's not the tranny mount. Hope this helps.
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
Collector Car
Jan 5, 2015 10:58 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
