coils, which ones are best
Old Mar 25, 2003 | 11:23 AM
bachehbad's Avatar
I'm changing my coils soon, which coils should i go with??
are the ones from GM the best?
Old Mar 25, 2003 | 11:39 AM
teke184's Avatar
just order an MSD for $40...they are generally better than stock replacements...
n2ceptor's Avatar
If you use the search forum, it will help on different opinions.... Most are all the same, some ppl use stock, some use MSD( but they have had problems with them in the past, dont know now) and I use an Accel...Had it since '99 so far no probs...
Old Mar 25, 2003 | 12:02 PM
hairbear21's Avatar
You can order a Jegs coil for about the same price as an MSD (I think the Jegs is cheaper). They claim more voltage than the MSD, but overall, they are all pretty much the same
Old Mar 25, 2003 | 12:08 PM
SloMofo's Avatar
I've had an accell on my car for a year now with no probs
Old Mar 31, 2004 | 08:07 AM
shadyyapper's Avatar
are coils easy to change out yourself? i have a bad one, and i also need a module... any thoughts..
Old Mar 31, 2004 | 08:16 AM
Mike383LT1's Avatar
coil swap
i would recomend the msd pt#8226 real easy to replace the coil and ignition modual (i would recomend gm there)are on the same barcket you will have to grind off the rivits that hold the factory coil in place dont worry the msd coil comes with new hardware the modual is held on with 2 screws dont forget to get some dielectic grease to put on the back of your new modual
Old Mar 31, 2004 | 08:20 AM
thanks... im waiting for a quote from Gm on this anyway, my car is in the shop as we speak... think it will be expensive from them?
should use the coils they have or should i get aftermarket?
Old Mar 31, 2004 | 11:08 AM
Grease's Avatar
All coils are about the same and the afetrmarket ones go bad just like the stock coil. I've had my car towed because my Accel coil crapped out on me. I've seen several people on here say that the stock 96/97 coil is the most reliable but I have a 95 so I just use the stock coil.
Old Mar 31, 2004 | 11:23 AM
CamaroBoy96Z28's Avatar
The stock coil is great, especially 96-97 coils. There is really no gain to be had going aftermarket.
Jeff1904
Jun 5, 2016 05:00 PM
93 RedBird
Nov 15, 2015 08:24 AM
PopoFormula
Oct 12, 2015 04:19 PM
68camaroboltz
Oct 5, 2015 01:46 PM
Z Power
Sep 19, 2015 11:19 PM
