Exhaust Leak
Old Mar 24, 2003 | 11:21 PM
Koors96Z's Avatar
Exhaust Leak
I'm pretty sure I have an exhaust leak where my i pipe meets up. What is the best way to fix the leak? Should I just have that part welded or is there a better way? Thanks
Old Mar 24, 2003 | 11:26 PM
94T56T-TOPDREAM's Avatar
(did you mena y pipe)??
If so try just tightening the bolts. Mine was leaking and I tighented the bolts, they were all about 2 complete turns loose.
Old Mar 24, 2003 | 11:29 PM
Koors96Z's Avatar
yes i meant y pipe, i tried tightening the bolts but the keep coming loose
Old Mar 24, 2003 | 11:37 PM
Wild1's Avatar
Double check where your exhaust is leaking. Test it by pouring 4 or more tablespoons of Automatic Trans Fluid into a fully warmed up and running engine. You can access the intake by removing the brake booster hose.
This will create smoke, which in a tight exhaust system will only leak at the tailpipe. But if you have leaks, then the smoke will leave from those openings.
About the bolts coming loose, you my want to consider getting new bolts. Perhaps they have past their "stretch" and loosen OR they were just ground below spec. Either way, they shouldn't be coming loose... more often than not they are rusted on...
F'n1996Z28SS
Aug 23, 2023 11:19 PM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
jasonduaine
Exhaust System
Mar 20, 2015 09:00 AM
Iamherefornow
Jan 26, 2015 04:57 PM
Brake_L8
Jan 20, 2015 09:44 AM
