used lt1
Old Mar 24, 2003 | 10:54 AM
NAZTLT1's Avatar
Post used lt1
Does 500.00 sound right for a 94 lt1 66k spun crank or main bering with fuel injection incl? Saw one on a local board may try to buy if it is a good deal. I am looking for something to build.
Old Mar 24, 2003 | 11:43 AM
bad79z28's Avatar
That's not a bad price, but a local junkyard here in northeast MS has Caprice/Impala LT1s for $500 running. I bought one last month for my Stepson's '94 Formula. Installed his ported al. heads and a CC304 cam and new timing chain on it and installed it in the car. It runs good.
Kevin
Old Mar 24, 2003 | 12:16 PM
viperkiller's Avatar
i paid $800 at junkyard for lt1 with 195lbs comp on all 8 and had everthing on th engine ex. manifolds fuel injectors all acceseries brackets starter tb wires opti(good) smog control everything
so id call you local junkman
Old Mar 24, 2003 | 01:10 PM
DubbyZ28Camaro's Avatar
If someone would confirm this, it would help, but in the past I have heard that if you have any spun main bearings, your block is trash. I would stay away from it.
Just my .02 and if someone could confirm this, it would help the both of us out.
Old Mar 24, 2003 | 01:18 PM
pull the crank and have the block line bored
then get oversized bearings will work but id rather not try
oldschool
Feb 9, 2016 09:21 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Noer
Feb 28, 2015 11:29 AM
InfernalVortex
Jan 17, 2015 09:35 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
