squeaking brakes!!
Old Mar 24, 2003 | 10:43 AM
JJJ93z's Avatar
Angry squeaking brakes!!
Ever since i have had my car the front left brake would squeak when i brake slowly but when i put a lot of pressure on the pedal it would go away, I was changing pads and getting rotors turned last summer when i found out one of the reasons why the front left was squeakin was b/c the caliper was sticking and not releasing (just the front left) so i replaced the caliper, and they didnt squeak that bad after that (just normal purring ) it sounded really good. then i put my car away for the winter and brought it back out 4 weeks ago, and this problem has persisted (about the FR brkes squeaking) it actually sounds like the warning tab is scraping the rotor , but the tab is no where near it b/c the pads are pretty new. So what is the problem i have here. Could it be in the brake lines? would an upgrade to stainless steel help out ? also i used reybestons pads and i want pads that are really queit and still grab hard, i was looking at EBC Greenstuff and Redstuff, and Hawk pads. any reccomendations?? thanks for the help
Old Mar 24, 2003 | 11:13 AM
93Z286Speed's Avatar
My front right does the same wtf! annoying as hell! i think im doing brakes this week or next, whats the cost on a stock rotor? i was thinking powerslots on ebay for like 90
Old Mar 24, 2003 | 11:23 AM
Clutch Install, Question
Me and a guy are doing my clutch this week, i have the Pressure Plate and the Disk.. what else do i need?
IE. Fluids, seals
all that fun stuff... i know i need my flywheel re-surfaced, but is that it?
Old Mar 24, 2003 | 11:25 AM
errrr, that was supposed to be a new thread.... myyyyy bad
Old Mar 24, 2003 | 11:43 AM
Severous01's Avatar
mine do the same thing, and i just replaced all four rotors and i use raybestos pads. ??? you got me as to why they squeek, i cant find a thing. no sticking or anything, fresh grease and all
Old Mar 24, 2003 | 12:38 PM
CM Dan's Avatar
mine did the same thing too. auto zone has some stuff but i forget what it's called. it's a reddish orange color and they keep it by the brake fluid. you apply it to the back on the pad, in between the pad and caliper. it stops any metal to metal rubbing which is usually the cause for squeaky brakes if the tab isn't rubbing. it's only like 4-5 bucks for a bottle that will cover 2-3 brake changes, so it's worth a shot. it worked for me. all you do is put a coat on the back of the brake pad where the caliper would push on the pad. let it dry for about 10 minutes and then put the pad back. my brakes haven't squeaked a bit in 2 months since i put that stuff on.
Old Mar 24, 2003 | 09:39 PM
JJJ93z's Avatar
maybe its just the reybestons pads
? CM Dan if you are at autozone n e time soon could you look at what that stuff is called? i went to the 2 that were close to my house today and neither of them even had a clue of what i was talking about thanks!
Old Mar 24, 2003 | 10:29 PM
VegasZ's Avatar
If your concerned about brake squeak, get the VGX pads. Theyre advertised as being quiet and they are. I have a convertible and the squeaking was driving me nuts untill I put on the VGX. Now it never ever squeaks.
Old Mar 24, 2003 | 11:25 PM
JJJ93z's Avatar
do the vgx grab well? also did u switch out your stock rotors ?? .. COLOR=blue]does anyone have HAWK pads or EBC pads????????[/COLOR] thanks
Old Mar 24, 2003 | 11:36 PM
VegasZ's Avatar
The VGX pads grab very well. I still have the stock rotors and am happy with the performance. I think they are great unless your doing some serious road racing in which case you would want a harder pad.
Old Mar 25, 2003 | 02:44 PM
awesome, something to look into deffinitly
Old Mar 25, 2003 | 09:31 PM
JJJ93z's Avatar
VegasZ
yeah , im not going to road race at all , its just for street use ,but i drive kinda hard so thats why i need some good grip. also where did u get yours from and how much did u spend
? i seen them in summit but i dont remember how much they were thanks!
Old Mar 26, 2003 | 08:28 AM
VegasZ's Avatar
I got mine from summit. $40.95 for the front or the back. I have them on both.
magman
Apr 15, 2016 03:08 AM
IndyZman
Oct 22, 2015 02:17 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
cohopefull
Sep 8, 2015 03:22 PM
maverickmk
Sep 1, 2015 09:17 PM
