!Air Conditioning
Old Mar 24, 2003 | 10:37 AM
rob2299usa's Avatar
Exclamation !Air Conditioning
I am in the process of removing and rebuilding my motor, and I have decided to strip the A/C off the car since it wasn't working anyways. I was just wondering what if anything I will need or need to do in order for everything to work out. Thanks.
Old Mar 24, 2003 | 11:07 AM
You need the "A/C delete" pulley and bracket from the 1LE cars. About $25. Some people need a slightly smaller belt after the delete. You need to decide if you want to pull the evaporator out of the heater box while the engine is still out. When you remove the condensor from in front of the radiator, make sure the rubber seals touch the radiator. Think that's about it.
Old Mar 24, 2003 | 08:31 PM
rob2299usa's Avatar
Question
How hard is it to pull the evaporator from the heater box and what are the pros and cons???
Old Mar 24, 2003 | 08:53 PM
NOMAD's Avatar
Cool
I used an idler pulley from a 2.8 chevy and fabbed my own bracket up out of aluminum. You have to space it with some thick washers, but it's perfect and was free
-Shannon
F'n1996Z28SS
Aug 23, 2023 11:19 PM
95chwagon
Jan 13, 2015 09:19 PM
Collector Car
Jan 5, 2015 10:58 AM
