EGR Question...I searched first :-)
Old Mar 24, 2003 | 08:15 AM
ltlhomer's Avatar
I searched and noticed no one had ever mentioned anything about the egr vacuum line (if that's even what it is). I have the blockoff plates, gaskets, and all that good stuff. But when I took off the egr valve, I noticed it was hooked to a little sensor type thing and then that had a vacuum line that ran into the intake manifold. I can probably take pictures of it tonight unless someone else knows what I'm talking about. Do I have to block off that vacuum plug that is sticking out of the manifold? And if not, what do I have to do? I'm removing both the AIR and EGR stuff by the way. Thanks for your help..
Old Mar 24, 2003 | 08:23 AM
ltlhomer's Avatar
Okay I kept searching and it looks like I just have to plug the hookup with a drain plug or something similar. If this is wrong, please correct me. I'm hoping to have the intake ready to bolt on soon.
Old Mar 24, 2003 | 08:55 AM
96ZRide's Avatar
Re: EGR Question...I searched first :-)
I have a 96, but I think they are the same from an EGR standpoint. The "sensor type thing" you're referring to is most likely the EGR solenoid. It uses pules-width modulation from the PCM to control vacuum to the EGR valve itself. If you are going !EGR, then it can be removed. And you're right, just block the vacuum line coming from the manifold to prevent a vacuum leak.
Good Luck.
Mikes 1994 z28
Oct 10, 2015 07:55 AM
autoxr166
Sep 25, 2015 04:21 PM
Fatdog2
Sep 16, 2015 11:04 PM
Sep 11, 2015 09:44 AM
Pwilson59
Sep 3, 2015 08:47 PM
