opti O-ring seal, is it needed, ASAP!!
Old Mar 23, 2003 | 09:53 PM
kirschman's Avatar
Exclamation opti O-ring seal, is it needed, ASAP!!
I'm installing the opti right now, the 2 O-rings on the drive are trash. I've done the cloyes, elec. w/p conversion,cps delete etc. This might sound stupid but I cant see how they are needed. The shaft just sits in the hole in the end of the cam, no oil is in the middle of the cam. Is'nt the seal in the cover for the opti all that is needed. Someone explain why this is needed, dont ride me out please
Old Mar 24, 2003 | 12:31 AM
ChuckZ28's Avatar
they wouldnt be on there if you didnt need them
Old Mar 24, 2003 | 05:58 AM
Mtrhds94Z's Avatar
My thought is at least for the early opti's that it stabilizes [helps keep centered] the driveshaft so as to not rip up the seal..
Not that it actually 'seals' anything?
Can't think of any other reason tho..
Old Mar 24, 2003 | 06:20 AM
gb95zconv's Avatar
Mine had oil on it when I pulled it out.....also as was mentioned, they probably keep it from vibrating(shock absorbers)
Old Mar 24, 2003 | 07:40 AM
With all the things the opti is blamed for, why skimp out on something that could be a liability later?
Old Mar 24, 2003 | 08:11 AM
GREGG 97Z's Avatar
As mentioned I think they are there to reduce vibrations from the cam to the opti. When I took my opti out recently there was only one of those rings left and it came apart in several peices when I pulled it out. I bought new ones at the dealer, a bag of 10 of them were like .99 cents. I would replace them, they are there for a good reason I'm sure.
Old Mar 24, 2003 | 09:11 AM
xxsaint69x's Avatar
u can also get em at your local hardware store.
Old Mar 24, 2003 | 03:36 PM
kirschman's Avatar
thankx for all the replies. I knew they where there for a reason, I just couldnt understand why. If ya dont ask u wont know
Old Mar 24, 2003 | 03:54 PM
GREGG 97Z's Avatar
Yeah, just walk in there and tell the guy "I need two GM optispark drive shaft O-rings for a 1997 LT1" and then wait for him to go, huh?
J/K seriously though, I'd just get em from the dealer to be safe, they were less than a buck for a pack of 10.
HectorM52
Jul 30, 2017 11:46 AM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
