rocker arm install, crank turns which way??
Old Mar 23, 2003 | 05:48 PM
grendal's Avatar
Hi guys,
I'm following Slim's cam install/rocker install instructions, and he indicates that at the "12 o'clock" position the engine should be at #1 TDC, and that if you turn it "90 degrees" it will be at the "3 o'clock position" and this will be the next piston in the firing order...
So I'm unclear, when FACING the crank, which way do I turn? Clockwise or Counterclockwise?.... Judging by the "3 o'clock" I'd say clockwise, but I want to make 100% sure....
Anyway, the process is officially started. The car is on ramps in the garage, the alternator is off, intake air hoses & MAF are off and I'm waiting for it to cool down so I can drain the radiator...
WISH ME LUCK!
Thanks!
-Michael
Old Mar 23, 2003 | 05:51 PM
Grease's Avatar
Clockwise
Old Mar 23, 2003 | 05:55 PM
Z95m6's Avatar
incase you wanted a second opinion, clockwise
HectorM52
Jul 30, 2017 11:46 AM
1775.Z28
Jan 11, 2015 10:51 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
Brandon Wittmer
Dec 7, 2014 12:15 PM
thenewkid
Nov 27, 2014 09:41 AM
