my car shakes some
Old Mar 23, 2003 | 05:14 PM
larson_lars64's Avatar
my car shakes some
basically my car sometimes wants to pull to a side and likes to shake a little bit. It doesn't go as straight as it should, but isn't bad enough i can't drive it. It is the worst above 70mph. I am thinking it could be a bent rim or the car is out of alignment. Has anyone else ever had a rim bend? Or is there something else it could be?
Old Mar 23, 2003 | 10:22 PM
Fatdog's Avatar
Cool
Once you get the wheel thing staightened out,and this does't fix this problem,then the drive shaft needs to be replaced.Go with the aluminum later model shaft.Hope this helps,but kinds sounds like out of balance wheels and tires.If you are spinning the tire,and the tire is spining more than 1/2 inch, within the rim,then you need a rebalance.Hope this helps.
Old Mar 23, 2003 | 10:26 PM
viperkiller's Avatar
rotat tires if rim is bent itll stop pulling or pull to other side
could be a bad tire
Jazsun
Dec 29, 2014 12:14 PM
1996LT1Z28
Dec 4, 2014 09:20 PM
USAirman93
Nov 24, 2014 03:37 PM
Bando
Oct 7, 2002 07:36 PM
