Where can I get a air bag setup for the rear?
Old Mar 23, 2003 | 02:30 PM
snksknr94's Avatar
I wanna get a single air bag to preload the suspension at the track. I guess something similar to what comes with the Eibach drag launch kit. Any suggestions??
Old Mar 23, 2003 | 03:40 PM
triumph's Avatar
www.jegs.com Steven
Old Mar 23, 2003 | 03:48 PM
The Air Lift 1000 kit is available from Summit of JEGs for about $70... includes two bags, two valves and the tubing. Use one bag and sell the other one.
Old Mar 23, 2003 | 07:18 PM
snksknr94's Avatar
Thank you, fellas!!
Old Mar 23, 2003 | 07:30 PM
snksknr94's Avatar
Is this the one that I need?
http://store.summitracing.com/partdetail.asp?part=9600
There are also a bunch that have different part #'s but no decsription of what they would work on. The one above is the only one that seems like it is correct.
Old Mar 23, 2003 | 07:41 PM
ucrazymonkey's Avatar
You can buy a single drag air bag from Thunder Racing for $35.
Old Mar 28, 2003 | 10:58 PM
fastcamz28's Avatar
I just got a single Air Lift air bag and plan to install on right side. Anybody have install directions w/ pics? Nothing came w/ single bag. Thanks for any help
Old Mar 29, 2003 | 12:38 PM
The bag should have come with a bottom "insulator" pad to protect the bag from the spring seat edges. Unbolt the shocks, lower the axle slowly, the springs will fall out. Put the insulator pad inside the bottom of the spring, on top of the seat. Clip the hose to the tit on the bottom of the bag and thread the hose through the hole in the insulator, put the bag in the spring and jack the axle back up, making sure the rubber seat is still in the recess at the top of the spring, and the spring is mounted correctly in it. Rebolt shocks.
Take the hose, route it to the end of the axle and up to where you want to mount the valve. Make sure you leave enough slack for the axle to go to full drop. Use nylon ties to hold it on the axle, and to the body. I mounted the valve through the sheetmetal so the top was inside the hatch well, and ran the line from the axle, through a small hole on the inner fender liner, and up to the valve. You need tiny spring clips to hold the hose to the bag and to the valve stem.
Always run the bag with at least 5# of air. At the track, start with 15# and then raise it or lower it for the best traction.
Bag in Eibach Drag Launch Spring
In this pic, you can see the rubber pad at the bottom of the spring, the hose coming out the bottom, curving up at the end of the axle, then sticking through the hole into the outer side of the inner fender.
Hose Routing
Old Mar 29, 2003 | 02:45 PM
fastcamz28's Avatar
Thanks Injuneer!!!!!
Mike
dale3in98
Feb 14, 2015 12:18 PM
rwferguson43026
Feb 6, 2015 10:06 AM
Airplanedoc
Feb 1, 2015 07:14 PM
squarehead
Jan 15, 2015 07:02 PM
Jul 4, 2005 05:00 PM
