Tune Up Help
Old Mar 22, 2003 | 11:51 PM
ibanezgod's Avatar
Tune Up Help
First off my car is overdue for a tuneup
94 TA 103K hasn't had one since before 64K miles and my car is bucking like a bull cuz theres something screwy with the distributor cap firing or something...
My mechanic wants about $1000 for a tune up
My buddy is going to do it for me...(he knows what hes doing)
________________________________________
I'm replacing:
Opti-spark ( I think that comes with the distributor cap no clue??)
plugs
wires
serpentine belt
Water pumps
fuel filter
new antifreeze
and i have to clean my K&N
_________________________________________
Should I replace anything else???
Old Mar 23, 2003 | 12:01 AM
n2ceptor's Avatar
I would hold off on the opti and waterpump.... Do the plugs, wires and fuel filter first.. Then see how the engine runs... Fluid changes are good also.. dont forget to open the air bleeds on the radiator system after changing it, because you could get air in the system....
Also, is the PCM throwing codes???? That would help find out if something is not functioning properly.....
Old Mar 23, 2003 | 12:02 AM
WhiteThunderZ28's Avatar
Might as well do an oil change too, and lube the car up too... It wouldnt hurt since your doing all that anyways
Old Mar 23, 2003 | 12:20 AM
ibanezgod's Avatar
I did an oil change 1000K ago... don't think i need one...
Old Mar 23, 2003 | 02:31 AM
ibanezgod's Avatar
I think my opti is bad actually tahts why i have to replace it... thats what my car-genius of a friend said...My mechanic said that my mechanic said my distributor is hitting or missing sometimes ...whatever that means...
Old Mar 23, 2003 | 04:31 AM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
how can they tell without first chaning the plugs and wires?
like i said in your other post-
the opti is the redheaded step child of this car
if you get a flat tire they will find a way a blame it on the poor opti
Old Mar 23, 2003 | 04:41 PM
ibanezgod's Avatar
I dunno exactly... my freind who is a mechanic said by the way my car is acting... its probably the opti...something with the sensors and it misfiring... cuz my RPMs act like their on crack without me doing anything and the car bucks like a horse...
Old Mar 23, 2003 | 04:53 PM
treyZ28's Avatar
mine did the same with a simple burnt wire
Old Mar 23, 2003 | 05:08 PM
ibanezgod's Avatar
well since my car i don't think has ever had a tune up... i'm sure its overdue.... it was blowing codes... i think they had to do with more than a wire problem
Aug 24, 2015 06:41 AM
sherwinZ28
11
Aug 15, 2015 05:38 PM
RallyRed701/2
Jul 27, 2015 02:55 PM
colts0455
Jul 24, 2015 04:51 PM
Shookiez28
Jul 23, 2015 01:55 PM
