I need some help, 1/4 mile ET's
Old Mar 22, 2003 | 10:54 PM
Joshua Hall's Avatar
I went to the track today and ran constant 13.6x with 2.2x and 2.3x 60' times.
I'm unsure why i'm running so bad or am i running right for my 60' times, plus i'm unsure about my tuning right now
My car is a 99 a4 with the following.... lid, hooker headers, hooker orp, magnaflow, and the diablo predator
Old Mar 22, 2003 | 10:59 PM
stik6shift98's Avatar
u need to hook better...your 60 foots could be a little better...
what tires are you using
Old Mar 22, 2003 | 11:12 PM
yokahama avs sports............ the track had a new launcing pad and everyone was getting bad traction but my mph was only between 101-103 and i thought that i should run better with headers
Old Mar 22, 2003 | 11:16 PM
TransAmLS1's Avatar
With your mods I would think you could run ALOT better than that. I would think very low 13s, and if you got some sticky tires maybe high 12s.
Edit-What is your elevation/location and what were the temps and humidity?
Old Mar 22, 2003 | 11:21 PM
blacknight's Avatar
What rear gears do you have? Are they 2.73's? I would get some 3.73's and a converter.
Old Mar 22, 2003 | 11:25 PM
i have a trans am ws6, so i have 3.23's.........
temperature was under 70..........
Could my a/f ratio be messed up that bad?
Old Mar 23, 2003 | 02:02 AM
2002-CamaroSS's Avatar
Probably was just a bad day at the track Those mods should be near 13s flat... Im still wondering what mines will run ...
Good luck next time at the track!
Old Mar 23, 2003 | 09:33 AM
nikkev's Avatar
Your 60's are killing you.You should be 2.1 at the highest with an auto.Drop those bad boys down to 2.0 or lower and your times will be right where they are supposed to be.
Old Mar 23, 2003 | 04:31 PM
Yeah hopefully next time my car will run low 13's but my mph was still so low for what i have,,,, a stock ls1 should be able to run that mph easily.......... hopefully getting my car on a dyno will tell what is wrong
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
D1SC383LT4
Jan 1, 2016 01:56 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
