Clicking noise coming from front of engine
Old Mar 22, 2003 | 06:31 PM
EviLBoX's Avatar
For a while now I've noticed a "clicking/ticking" noise coming from the front of my car. Today I put my car up on Rhino Ramps and crawled underneathe and I've narrowed it down to what sounds like the timing chain cover. I know it's not an exhaust leak, it doesn't have that kind of "tick" to it. It's also noticeably louder when the car is cold and in drive vs. park. I noticed a little bit of oil and dirt on the timing chain cover also, but I've never had any oil collect on the ground. Any ideas what may be causing the clicking/ticking noise in that area?
Old Mar 22, 2003 | 06:48 PM
1994TransAm's Avatar
well unless your chain is about to take a dump.... i'd bet 5$ on your tensior pully.
they are easy to remove...mine lasted 113,xx miles untill it started to make a clicking noise.
best way to tell is.. get the car on ramps, turn the engine on and crawl under with a long screwdriver... and put it against your ear...listen for a clicking on the timing cover or the pulley tensioner.
be carful
Old Mar 22, 2003 | 06:52 PM
EviLBoX's Avatar
Thanks for the reply. If it is the tensioner pulley, what's causing the noise? Do I just replace the pulley?
Old Mar 22, 2003 | 08:23 PM
To test the tensioner theory, just remove the belt, fire it up and listen again. Obviously that will remove any other belt driven item that might be causing a noise.
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
jj71787
Dec 30, 2014 02:15 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
Dec 4, 2014 11:56 AM
siguy
Nov 27, 2014 10:07 AM
