injectors
Old Mar 22, 2003 | 12:46 PM
akafred's Avatar
injectors
what size injectors do i need for mod's in sig? are the stock ones big enough? also if i build a 383 this summer will the injectors i buy have to be replaced again?
Old Mar 22, 2003 | 12:50 PM
joeSS97's Avatar
Your stockers are ok for now.Definitely need to upgrade with a 383.
Old Mar 22, 2003 | 01:46 PM
96z's Avatar
96z
Im going with 36's for my 383...stock ones are generally good up to 400-425 crank HP....after that the duty cycles tend to get too high.
Old Mar 22, 2003 | 05:37 PM
akafred's Avatar
thanks for the info. so there isnt any benifit from bigger injectors with only a measly hotcam
Old Mar 22, 2003 | 06:39 PM
Josh-'04 GTO's Avatar
This calculator is pretty handy for injector sizing:
http://www.smokemup.com/auto_math/fuel_injector.php
Old Mar 22, 2003 | 09:19 PM
akafred's Avatar
so would 30 lbs injectors work on the steup i have and the future stroker.
Old Mar 22, 2003 | 09:31 PM
gb95zconv's Avatar
Yes
Old Mar 24, 2003 | 06:20 AM
IDOXLR8's Avatar
I would say 30 lbers if you plan on a NA 383 or 36lbers if you plan on spraying it.
Old Mar 24, 2003 | 08:09 AM
rickb@lynk.com
Guest
Posts: n/a
I have good logged data before and after a switch to 30# SVO injectors. I was seeing 90+ duty cycle between 3400-4400 at 85% throttle with stock injectors. Since changing to 30's with fuel pressure at 44psi I have set computer injector constant to 33.13 to get blm's right at part throttle. I have monitored a 68% duty cycle between 5100-5600 at 100% throttle. I have not pushed the new engine too hard. I would think this would support 150 dry nitrous with the fuel pressure at 48 or so. If you don't want to jiggle the fuel pressure you would probably want a true 36# or 38# injector rated at 43.5 for any dry nitrous. The 30# SVO's I am using are rated 39.5 psi.
Old Mar 24, 2003 | 05:18 PM
gb95zconv's Avatar
With a wet kit the 30# would still suffice , but a fuel pump upgrade would be needed wet or dry.
G-BODYT56
Jan 14, 2022 11:14 PM
magman
Apr 15, 2016 03:08 AM
autoxr166
Sep 25, 2015 04:21 PM
form94
Sep 23, 2015 07:30 AM
95blkss
Sep 22, 2015 03:18 PM
