Autocross and Road Racing Technique There is more to life than a straight line
GW upper control arm bushings??
Old Mar 22, 2003 | 12:10 PM
Dave B's Avatar
I already have GW upper control arms which are great pieces. I use them for track use and have the more expensive del a lum bushings which are also excellant pieces. Problem is the Canadian Solo 1 series has developed a new set of rules which means I need to go back to the cheaper type of bushing but can still use the upper arm. Has anyone had any experience with this type? Is it a poly type or rubber?? Does it install in the arm easily ( which the del a lum do) or is it pressed in ?? I have emailed GW but they have been slow to respond.
Old Mar 22, 2003 | 11:34 PM
94bird's Avatar
I have a set with the delrin bushings that I haven't installed yet. They appear to be pressed in. Global West sells replacement delrin bushings for a cheap price for what I hear and they shouldn't be that hard to change out.
Koby
Jun 28, 2015 04:46 PM
dbrockma
Feb 16, 2015 02:56 PM
Jason Short
Jan 19, 2015 06:34 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
