Header Bolts
Old Mar 22, 2003 | 03:12 AM
Wildwill532's Avatar
Header Bolts
Whats the best way to get the passenger side header bolts off and what angle to work from thanks!
Old Mar 22, 2003 | 03:17 AM
texasTA's Avatar
Some of them are VERY MUCH easier to get to if you go from the bottom with the starter removed. I believe the 3, 4, 5, 6 header bolts are all easier from down low (although it might just be 4,5,6). The first three are right there.
Old Mar 22, 2003 | 11:04 PM
i got all but like the second to last one on the passenger side in the back its like by the damn dip stick how do i get that one sence theres 6 bolts per header/manifold
Old Mar 22, 2003 | 11:05 PM
blown383's Avatar
Get it from underneath its your best bet.
-B
Old Mar 23, 2003 | 12:04 AM
95TA8280's Avatar
PATIENTLY do it from the bottom......when you get pi$$ed, just relax, take a beer, and sit back...go back 10 minutes later!
Old Mar 23, 2003 | 05:05 AM
texasTA's Avatar
Have you not taken the dip stick out? If not, then unbolt the one bolt that holds the dipstick to the block. Slowly from the top of the car pull the dipstick and tube out of the block by slightly wiggling (sp) it back and forth. After the dipstick is gone, you are on the home stretch.
Old Mar 23, 2003 | 06:06 AM
zyal8er5.slow's Avatar
to get to my last header bolt i laid across my engine from the driver side and got it from behind with my right hand
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
maybe2fast
Mar 16, 2015 09:45 AM
SavageZ28
17
Jul 14, 2002 11:04 PM
