P.O.S. CSI water pumped died...
Old Mar 21, 2003 | 02:38 PM
solid95z's Avatar
Angry P.O.S. CSI water pumped died...
That's how I felt last night. It just died for no reason at all. It is less than a year old (about 7 months to be exact) and the motor in the pump just quit. WTF?
Mezierre here I come.
What problems have you guys had with your CSI pumps? Maybe I just had bad luck with mine.
Old Mar 21, 2003 | 02:40 PM
Smokinsometires's Avatar
How many hours were on the pump?
They do die eventually
People have had problems with Mezeires, also.
I will be playing it safe and sticking with an OEM.
Old Mar 21, 2003 | 02:44 PM
joeSS97's Avatar
Mines been in about a year now with no problems.I have relay and indicator light if it quits.When it does die ,I am going to use another CSI.Piece of cake to install now.
Old Mar 21, 2003 | 02:47 PM
GREGG 97Z's Avatar
How did you have it wired? Did you use a 15 amp inline fuse? Just curious, I installed one recently and no problems with it yet.
Old Mar 21, 2003 | 02:53 PM
solid95z's Avatar
I had a 15 amp fuse on it and it did not blow. There was not a short or anything that I can see. From what I can tell the motor in the pump just died. I took the pump and jumped it directly to the battery and it does nothing. DEAD
I drive the car all the time (it's my only car) and it has been good until last night. The motor in the pump just seems to have died for no reason.
Oh well... I am thinking about going with another stock pump. dunno yet though.
Old Mar 21, 2003 | 03:00 PM
Mikael's Avatar
CSI and Mezeire use the same motor.
Old Mar 21, 2003 | 03:05 PM
Dr.Mudge's Avatar
Yep, same motor, no problems on my CSI, been over a year now. I use a relay setup as well.
Old Mar 21, 2003 | 03:08 PM
solid95z's Avatar
If that is the case then how can the advertise 2 different pumps? One being a standard electric pump for LT1 and the other being a Heavy Duty electric pump for LT1.
Is it that they both use the same company to make the pump or is there more to it?
Old Mar 21, 2003 | 03:09 PM
atljar's Avatar
How do you wire the warning light?
I have a link to the schematics (sp?) page, but im no electrical engineer. Someone just tell me what goes where?
Jared
page is here http://www.akmcables.com/2ledmez.jpg
Old Mar 21, 2003 | 03:11 PM
solid95z's Avatar
I think I just ran into some bad luck with the pump and it died.
I just wanted to vent for a bit and see if anyone else had any bad luck with theres.
Scott
Old Mar 21, 2003 | 03:12 PM
atljar's Avatar
OK looking at that a little more carefully, it seems that it will use the pump power wire as a ground if it shorts out? Correct?
But i still dont see how the bad ground light works?
Old Mar 21, 2003 | 03:16 PM
BigRich's Avatar
just curious, did you have an indicator warning light? how did you realize it? was your temp going to the red?
Old Mar 21, 2003 | 03:19 PM
solid95z's Avatar
I did not have an indicator light. I noticed that the temp was getting up after about 2 miles of driving. I pulled over and when I turned on the key I noticed the pump was not coming on.
Old Mar 21, 2003 | 03:31 PM
Dr.Mudge's Avatar
Mez makes 2 pumps, HD and regular.
Old Mar 21, 2003 | 03:48 PM
GREGG 97Z's Avatar
I'm not sure how that works but I am going to use this guide for the CSI. I think this way the light will always be on unless the power to the pump fails. Not sure if it would go out if the motor just died or burnt out though. I need to install that light along with the switch on mine this weekend.
HarleyZ28
Oct 5, 2015 06:23 AM
95z_28_camaro_4_Ivan
May 8, 2015 09:56 AM
Blood type Z28
Apr 8, 2015 11:34 PM
pologreen97z
Dec 2, 2014 10:42 AM
Zone
Jul 29, 2002 07:43 PM
