forged crank or not?
Old Mar 20, 2003 | 06:33 PM
tkatchev69's Avatar
Ok, here's my deal. I'm either going to get the Eagle Street Stroker kit, or the Eagle Competition Stroker kit. The Street package doesn't have a forged crank, but is $500 less than the Competition package. I'm doing a stroker kit, AFR 190cc heads, and a cam, shooting for between 450 and 500 hp. The guy assured me that for my power needs, the Street package would be sufficient. I am going NA, with no power adders, and I want it to last a while. Any thoughts or opinions? Thanks.
Old Mar 20, 2003 | 06:40 PM
Teal94Z's Avatar
The Non Forged should do just fine, even your stock crank was rated at 500 hp I believe, someone correct me if I am wrong..
Old Mar 20, 2003 | 06:41 PM
Mindgame's Avatar
Back in 77' I had a Vega bracket car... 355 chevy small block, 5.7" pink rods, 292 heads, solid cam, 2-bolt mains w/studs, and a cast crank. Use to run high tens with that thing spinning to 7200. I ran that engine every weekend for 2 seasons like that before doing a refresh on it. I've ran quite a few other cast iron cranked small blocks on this level (budget bracket). They'll take alot more abuse than most people will give credit. For your proposed power limit... it'll do the trick just fine as long as the machine work is there. Good machine work will make or break a crank... pun intended!
-Mindgame
Old Mar 20, 2003 | 06:46 PM
tkatchev69's Avatar
Thanks guys. You've set my mind at ease. I can't wait to feel this power!
Old Mar 20, 2003 | 06:56 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
mine isn't forged. im not really concerned.
I'm going with a callies when i load up on the dope though
Old Mar 20, 2003 | 07:09 PM
gb95zconv's Avatar
Only thing I would suggest is seeing how much you machine shop will charge you to do standard 4 bolt caps on the 3 center mains. Mine is only charging $200 to line hone and do the 4bolt caps....and that includes the caps ( I allready had the studs) The line hone alone would have been $150. Anyway that crank should work for you....Im using the Eagle forged crank, but I also am going to spray at least a 150 shot.....well worth the $400 extra dollars for my app.
truthmatters
3rd Gen / L98 Engine Tech
Aug 19, 2015 04:09 PM
4586
Aug 18, 2015 07:08 AM
karpetcm
Aug 14, 2015 03:02 PM
Catmaigne
Jul 14, 2015 05:17 PM
