LT4 head gasket boost compression?
Old Mar 20, 2003 | 01:41 PM
Formula03's Avatar
I dont remember where i read it but it said that the LT4 head gasket boosts compression and i was wondering if someone knew if this was true and could explain why. thanks
Old Mar 20, 2003 | 02:05 PM
dabear95's Avatar
The impala head gasket increases the compression ratio. I don't think there is a head gasket specific to the LT4 engine. Its really the same block as the LT1.
Compression ratio is determined by how much the piston squeezes the fuel/air mixture in the combustion chamber. If you use a thinner than stock head gasket, you have less space to compress the air. Since the piston still moves the same amount, the fuel/air will be compressed more.
Hope this helps!
Jason
Old Mar 20, 2003 | 02:38 PM
94F1Z28's Avatar
The LT4 head gasket would raise compression but it would be very little and not worth the effort.The impala ss gasket would raise it about .4.The LT1 gasket is .050"thick,the LT4 gasket is .043" thick and the impala gasket is .028".As you can see the impala gasket would be the best one to use if you want to raise your compression.
Old Mar 20, 2003 | 02:45 PM
dabear95's Avatar
Well I didn't remember one!
Old Mar 20, 2003 | 02:48 PM
94F1Z28's Avatar
I am getting the gasket specs from the 2002 Gm performance parts catolog.I am not sure how accurate it is.
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
