Upgrade and questions, please help
Old Mar 20, 2003 | 03:19 AM
Axel's Avatar
I have a 94 Z with almost 60k (A4) and mostly stock (except the borla and FIPK) I was looking maybe to give it a little more kick.... I am new to the mod game so please help me out. I have been reading up and are interested in 3 things...... a Granatelli MAF sensor, hooker headers, and a Vigilante TC. Which ones do you recommend??
Will the MAF mess up my computer?
Will the headers screw up my emissions? (Cali :I)??
What the hell does stall mean for the TC???
The new guy
Old Mar 20, 2003 | 03:47 AM
chesee48's Avatar
First off, Welcome to the board!
You can get shorty headers i.e Hooker, MAC, BBK, Edelbrock, RK Sport, AS&M, SLP etc and they will ALL pass emmisions.
The MAF in my eyes is a WASTE of money. Save it for something else.
The "stall" refers to the rpm the car stalls at.
A good and very QUAILTY stall is a Vigalinte (spelled wrong) Stall. A 2800 would be perfect for you. Some say 3000 or even 3200, but they you might run into programming problems with hte higher stall.
What gears do u have now? A 3.73 gear and 2800 stall is a GREAT combo. REAL SEAT IN THE PANTS gains. No hp though however.
If i were you i'd get the headers, stall, maybe gears depending on what u have and some custom programming i.e www.madz28.com or www.pcmforless.com .
Then work your way up from there. Too more HP or suspension route etc.
A cut-out is a great-cheap mod as well. 35.00 for the cut-out and like 35 to get it installed at a muffler/speed shop.
Again, welcome to the board!
Old Mar 20, 2003 | 04:09 AM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
he covered it very well.
you also might want to look into nitrous.
Its safer than you would think.
A small cam and mild headwork never hurt either.
I think one of the greatest bangs for the buck -
1.6 roller rockers
jegs has the crane engergizer ones for $200.
If you have stock rims, trans am 5 star wheels weigh a nice 6lbs ligher each. that means much better accell and braking- and they are cheap as hell and look 10x better.
You can also get new springs, shock.struts.sway bar/ sub frame connectors ect- all these will help (depending on what you want them for strip or twisties)
The LS1 brake upgrade for $250 is also a very appealing mod, even an aluminum driveshaft for $100 is a nice hp gain to the wheels and it will reduce your drive shaft vibrations.
whatever you do-
JUST GET A BIG *** TRANSMISSION COOLER FIRST!
Old Mar 20, 2003 | 05:14 AM
94F1Z28's Avatar
The headers should be first and then a high quality stall converter,as for the MAF you may want to spend the money else where.
Old Mar 20, 2003 | 10:13 AM
rickb@lynk.com
Guest
Posts: n/a
I would say headers and agree that adding 1.6 roller rockers is easy. You probably do not want to go to a higher stall speed until you add a bigger cam.
Old Mar 20, 2003 | 12:02 PM
chesee48's Avatar
Yea but a stall/gear combo without the cam right now is still a great thing to do in my eyes.
Old Mar 20, 2003 | 12:37 PM
Draco's Avatar
headers, a stall, roller rockers, and some sticky tires and you could hit 12's.....
Forget the MAF, total waste.
Old Mar 20, 2003 | 09:50 PM
Axel's Avatar
You guys are awesome. I think I have decided to get the shorty headers.. How much to buy them/ have them installed... lets use hooker as example....
One more question. I hear a lot about "gears" how do I find out what I have, and where can I read about/upgrade them on the net? Is it important for me to upgrade?? Thanks again guys. (or girls)
Old Mar 20, 2003 | 09:56 PM
Axel's Avatar
Old Mar 20, 2003 | 10:01 PM
chesee48's Avatar
look at your codes...should start "GU" THEN 3 or 5 etc...
Old Mar 20, 2003 | 10:06 PM
Axel's Avatar
Old Mar 20, 2003 | 10:08 PM
Axel's Avatar
Sorry for the duplicate postings, I hit the "back" button. I am now looking up gears. Thanks, do you recommend any certain headers brand name??
Old Mar 21, 2003 | 12:45 AM
chesee48's Avatar
"You can get shorty headers i.e Hooker, MAC, BBK, Edelbrock, RK Sport, AS&M, SLP etc and they will ALL pass emmisions."
The Best and most expensive: AS&M
Then followed by Rk sport (those 2 are both mid length headers and are almost identical)
Then MAC, Hooker, Edelbrock, SLP, BBK
Those are what i suggest in order. Also Coated is a HUGE plus.
Good luck!
Old Mar 21, 2003 | 05:11 PM
Axel's Avatar
Why are coated headers a huge plus over regular headers... if I get the mid length headers (the rk sport maybe) will I pass emissions??
the big question with the rk sports..... Will I notice a difference?
Old Mar 21, 2003 | 06:26 PM
rickb@lynk.com
Guest
Posts: n/a
The coated header helps reduce underhood temperature and they will last longer.
